Toy hauler with Azdel construction.
Midtown
Are there any company's using Azdel laminated walls other that lance?
4 REPLIES 4
delosholly
I am not sure what walls you refer to, inside or outside, but Livin Lite's toy haulers are:
Exterior?/?Construction Features
EXTREMELY LIGHTWEIGHT DESIGN – Towable by Most Trucks & SUVs!
6-Sided Aluminum Super Structure
5" Double Aluminum Frame w/3" Tongue Tube Middle Rail – 3-Tier Frame
Composite Material throughout unit (water and mold resistant)
All Aluminum Floor Decking w/D-Rings (can order w/no lino)
Vacuum Bonded Walls, Laminated w/Azdel 3-Tier Glue Process (stronger, more durable)
.40 Aluminum Siding w/Full Body Automotive Paint (6 Color Choices)
6-Sided Block Foam Insulation including Front Radius
Alpha Superflex® Roof w/12-Year Limited Warranty (more durable, less chalking & streaking)
Dexter® Torsion Axles
Auto-Adjusting Brakes w/Easy Lube Axles
Delos & Holly
2013 Camplite Truck Camper 10.0
2014 Ram 2500 Reg SRW LB
2012 Burgman 650
Midtown
I have a feeling it's just going to be the ones that offer a toy hauler in 1 or 2 floor plans.
Bumpyroad
if a used RV, Ascend did.
bumpy
tinner12002
Coachman uses it according to web search.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
