Trailer sway issies
fowlthing
View Profile
Posted: 09/03/22 08:26am Link | Quote | Edit | Print | Notify Moderator
2020 Model. Pulling with 2021 Ram 2500 Diesel. Have 3000 miles plus with no issues.
Now at speeds as low as 30 mph can hit a bump and side to side rocking translates into trailer sway. Worse going uphill. Had a trip this weekend and put two new tires on the rear axle. My tire shop only had two.
Is this axles out of alignment?? Shocks on the truck? ( 30k miles on truck).
I pulled the tires off and bearings are good. Measured and axles are same distance between tires. Did not measure to the pin.
Tread is still good on front axle. And was good on the two that were replaced. Wear is even. Could not detect that they were out of round when jacked up and spun the wheels.
Any help is welcome. Have years experience of towing trailers. The sway is dangerous. Not a slight annoyance. Thanks.
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
32 REPLIES 32
Cummins12V98
Head in sand syndrome!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fowlthing
Will check the truck for a broken spring or sway bar. Thanks for the input from everyone
2017 Ford 350 SRW
may switch to a Ram
Flan
Take a look at the sway bar, make sure it isn’t broken or missing bolts where it attaches to the axle.
Heartland Prowler 27LX
19 Ram CTD 2500
fowlthing
Using an Anderson hitch. And this model does not have the basement I have seen it but this Milestone does not have it. Thanks for the info. No weight changes from the first 3000 miles of towing. But something must be broke somewhere.
Have not checked the springs on the truck yet. Other springs and axles to pin box are the same.
Thanks for the help.
2017 Ford 350 SRW
may switch to a Ram
Cummins12V98
If Icemans numbers are what the OP is towing he is WAYYYYYY out of his league with any 2500 SRW.
Load up, hit the CAT Scales and report back. Also let us know who told you this combo "will tow just fine" !!!!!
TXiceman
I addition to being under trucked, that model Ram 2500 has rear coil springs. This is known to be less stable than a leaf string truck.
That model trailer has a rear basement (under the living area). If this is loaded too heavily, it will lighten the pin weight which can lead to poor handling.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
MFL
Nomad II
Nomad II
^OP has not responded to several asking about "what hitch using"? If OP is using some type of gooseneck adapter to save hitch wt, a broken frame/weld could be the sudden cause of problem.
Not as likely if using a conventional FW hitch.
Jerry
GIB2
You mentioned all the suspension I'd be looking on top of pin box to make sure no welds to the trailer frame have broken . The weld on our fifth wheel are less than desirable although they never broke. Costs nothing to look.
nickthehunter
Nomad II
Nomad II
Do you have something really heavy loaded behind the axles of the trailer?
TXiceman
UVW1
14200 lbs
Hitch Weight1
2900 lbs
GVWR
16800 lbs
Length2
41' 4"
I think you do not have enough horse to pull that trailer per the above numbers. A loaded camper of 16,800 lbs will have a loaded pin weight of roughly 3400#.
Forget the unloaded weights unless you never plan to add anything to the trailer including food, clothes, water or propane. But I have yet to see a camper that does not bring along clothes, food, propane, pets, wife and kids.
Ken
JIMNLIN
Agree with weighing your trucks front and rear axle while hooked to the trailer and road ready.
Your 2500 has a 6000 rawr for carrying all the load in the bed.
Many newer gen 2500 Ram trucks rear axle can weigh in the 3000 lb range leaving around 3000 lb in the bed payload.
Overloaded rear axle (tires/wheels/rear spring pack) and worn out shocks on a truck with rear coil springs can make a bad handling combo.
A 2500 with a 6k rawr isn't a good replacement for a one ton srw truck with a 7230 rawr = a 1230 lb loss for carrying weight in the bed.
A 5th wheel trailer adds little to no weight on the trucks front axle.
Get all the trucks axle weights first and go from there.
fj12ryder
What kind of tires, and what psi are you running them on the truck? What kind of hitch? Do you see any movement in the front of the trailer when you set it down on the truck, like it's flexing some? I'm assuming you've checked all the shackles, and any related suspension bolts, and hangers.
And I'll agree that is one big a$$ trailer for a 3/4 ton truck. Have you scaled the truck and trailer?
Howard and Peggy
"Don't Panic"
I’m with Jerry on this.. my buddy has a Solitude 375RES that we took my truck to pick up down in Nashville (16 hrs) ..
Towing that trailer with a 2500 is a stretch… I'm assuming your RAWR and tire capacity are both well over max…. Those are the 2 numbers that i look at..
If your over your tire capacity, that could give you the feeling of squishy/squirming..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MFL
Nomad II
Nomad II
That is a big FW, may be close to 4K pin wt when loaded. A bit much for the 2500 with softer springs than your F350 had.
You likely do need some suspension help. Some airbags, Timbrens, or other.
Jerry
bgum
Check all tire pressures truck and trailer. Is the two new tires the same size and grade ( C D E F)as the front two?
