โMar-10-2017 11:56 AM
โMar-12-2017 03:48 AM
Road Phantom wrote:
I have the Companion Hitch and absolutely love it. It's an easy hookup. Mine cost $900 from the dealer.
โMar-12-2017 03:47 AM
work2much wrote:Wild Card wrote:
I have a 15 Ram dually 4x4. I am at 59" to top of bed rails. I am pullig a Voltage Toyhauler and run about 2-3" high in the nose with 7.5" bed rail clearance.
Buyng new truck spring for the Ram factory air ride.
I was definitely considering this. Does the truck ride lower unloaded with the air ride?
โMar-11-2017 04:55 AM
work2much wrote:Jhurk wrote:work2much wrote:Jhurk wrote:
I have a 2014 Dodge Ram 3500 Reg box pulling a 2009 Cardinal 34'. I used the Anderson Ulitmate Aluminum hitch (35lbs) great hitchmfor a short box and 200 lbs lighter than some heavy hitches. I had to raise my Cardinal 5 " to make level but all is good. I believe the newer FW are taller to accommodate the newer TV.
Thanks. Is raising the trailer as simple as blocks and longer u bolts?
It's a little more than that to do it right I believe it's like a sub frame with a cross member for support.
Thanks. What I am trying to avoid.
โMar-10-2017 09:55 PM
โMar-10-2017 09:31 PM
โMar-10-2017 09:22 PM
Durb wrote:
The tailgate height on the Ram dually is 57 inches and I believe the overhang on on the Grand Design is 62", maybe a little less. A couple of inches of truck squat should put you about right on to tow level. Please double check these measurements.
โMar-10-2017 09:08 PM
โMar-10-2017 04:46 PM
โMar-10-2017 01:53 PM
โMar-10-2017 01:47 PM
โMar-10-2017 01:35 PM
โMar-10-2017 01:33 PM
korbe wrote:
Our truck is pretty standard and the side bed rails are 54" high. Our 5er fit perfect without any adjustments.
โMar-10-2017 12:48 PM
โMar-10-2017 12:27 PM
