Dec-20-2017 01:13 PM
Dec-29-2017 09:34 AM
Bowti wrote:
Tom, one mods that I did need to make, was better access to the dump levers, so I put in this door, along with adding an 10" extension to the dump pipe.
One of the best mods I made, as I no longer have to get on my knees to reach underneath the unit to reach the pipe or levers.
Dec-29-2017 07:22 AM
Dec-29-2017 04:56 AM
Bowti wrote:
Tom, I missed it, that you had it figured out. The use of the Yakima racks allow for quite a few different types of carrying systems.
We love the Cougar and haven't had any problems except for the front decal which was replaced under warranty and the need to replace the crappy tires.
Dec-28-2017 03:32 PM
Dec-28-2017 01:53 PM
kevden wrote:
[img][/img][img][/img]
I use a Yakima mega warrior with one extension. I might get another extension at some point. The oem cross bars on the truck were too flexible for the rack, so I replaced them with unistrut. It is a heavy rack, if I were to do it again I would look at aluminum racks
Dec-28-2017 01:52 PM
Bowti wrote:
You could also try something like this
Not too expensive to do, and you can make it to haul just about anything.
Dec-28-2017 08:12 AM
Dec-27-2017 06:00 PM
Dec-24-2017 05:12 AM
Dec-22-2017 04:36 AM
CabinetmakerII wrote:
Wintering in Arizona I have seen some amazing ideas of roof racks with an assortment of apparatus to get "stuff" up on the roof. From side by side OHV's, welders, and even generators. I cringed watching one individual backing his side by side down a series of ramps from the roof of his crew cab down to the bed then finally to the ground. If you can dream it, somebody can build it... Good luck!
Dec-21-2017 03:16 PM
Dec-21-2017 10:41 AM
camperkilgore wrote:PopBeavers wrote:
A friend of mine stores his sand rail up there.
I'd like to see that. Must be a stout rack.
Dec-21-2017 10:01 AM
Labman7 wrote:Yep, that one is a good one, but out of my price range.
Trailer life has a article on installing a roof rack in the March 2017 issue, available on line.
Dec-21-2017 09:19 AM
