Aug-25-2014 12:09 AM
Sep-03-2014 03:16 AM
Sep-03-2014 01:21 AM
IH_Fan wrote:
Hi folks,
I’ve been watching/reading the weight posts with interest and have seen the difference of opinions and approach.
I’ll throw in that government regulations and manufacturer’s desire to maximize profits by creating commonality in parts adds to the debate (or confusion!).
Here’s my thinking on the issue and I’ll use my 2013 Ram 2500 CTD Longhorn as an example.
The GVWR on my truck is 10,000 lbs. That falls directly under the wire of the next class of vehicle of 10,000 lbs per DOT regs. This is where manufacturers have the ¾ ton trucks built under. Over 10,001 lbs is 1 ton + territory and with that comes increased licensing and registration fees. In other words a Government imposed threshold.
This same truck shows a GAWR rear of 6,200 lbs and front of 5,500 lbs. Add these 2 together and the GVWR is in fact 11,700…….not 10,000. Did Ram (or the other manufacturers) do this on purpose? No. What they did do is standardize parts in a narrow truck market. Lots of ½ tons are sold, but far fewer ¾ or 1 tons. The best way to maximize profits is to keep as many parts between these two models the same. That is why for all RAM model years (except the 2013 Ram when the ¾ and 1 ton had different frames transitioning to the new K50 frame) the ONLY difference between the 2 was/is an added leaf spring and different tires. To be sure, Ram has made the Aisin transmission an option in the 1 ton. Personally, I think you’ll see the 68RFE will be phased out in future (a maximized design) with all ¾ and 1 tons with the Aisin as the torque and HP wars continue, but I digress……
The rear tires on my Ram are maxed to 6,390 lbs (Firestone Transforce AT)…….Ram used a tire that is higher rated than the rear axle. Yet this is the EXACT same axle as found on the 1 ton….
Based on this, my recommendation to anyone researching is this:
The big number to be mindful of is the rear axle, followed by the tire rating. The payload argument has validity and perhaps more so in some earlier model years. But in the newer trucks, payload is becoming more and more of a false start in the ¾ vs 1 ton argument, only because of Government regulations and manufacturers trying to maximize profits are not aligned with each other.
Yes, you need to be safe…..Yes, you need to drive wise and to changing road conditions…..Yes, you can only buy a set up you can afford….
But – this argument is a bit more complicated than on the surface of things. No, this is not justification to pull a 40’ trailer with a 1986 K-car!!! This is about common sense…….
Sep-02-2014 08:17 PM
Sep-02-2014 07:00 PM
Sep-02-2014 01:18 PM
kohai wrote:.
There is a sticker on the inside of the driver's door that will tell you how much weight you have available for payload on your specific vehicle.
Sep-02-2014 01:16 PM
Sep-02-2014 01:11 PM
Sep-02-2014 12:57 PM
Sep-02-2014 12:52 PM
Sep-02-2014 06:55 AM
rhagfo wrote:NC Hauler wrote:smurf wrote:
Well guys we have been full timing for 10 years / We have an 04 364 Everest 4 slides . I also have a 50 gal tanking my bed. OO I for got we pull it with an 04 GMC 2500 HD /Allison Tran. !!! I have 150,000 miles . I have weighted it full of fuel ( 80 gal )loaded 5th wheel and was a 150# over on front axle . We travel over west of the Mississippi River CO. WA. OR. Mont. ID. Ca. NM. Minn. And all points in
between .:)
Well, actions speak louder than words...it appears it works for you, and you're pushing the limits even more by adding an additional 365# of diesel fuel. You and the poster below you appear to make it work and both of you state, by mileage towing, it is quite safe...I still don't know if I would advocate towing, pushing the limit of trucks axle ratings, but I tend to err to the side of safety....BUT..... I guess the two posters who have been towing 14,000# 5er's, "noticed" that the OP's 5er has a GVW of 1500# MORE than their 14,000# 5ers at 15,500# GVW?? Significantly heavier, so if above poster is over an axle weight with a 14,000# GVW 5er, IF OP loads heavier than last two posters, would the two posters recommend for OP to "go ahead" and still do it:h..I can't advocate not being safe..
I towed just under 14,000# with an 03' Chevy D/A as I stated earlier with no extra fuel,and trucks configuration was ext cab/short bed....I did it, but on some mountainous secondary roads felt I needed a little more truck...I can't imagine on top of 14,000#, possibly adding ANOTHER 1/2 ton or more..I personally wouldn't recommend towing a 15,500# 5er with the 3/4 ton the OP has....
This is where I am at, for sure not weight police, BUT there are still limits as to what you can exceed the limits of your TV.
I don't often suggest others do as I do, we are over the TV GVWR by a decent amount, BUT still have about 500# of axle capacity both front and rear.
That said the rear axle rating is 6,084# just what the stock 245/75-16E tires rate out at. TV is Camper Special bigger springs and larger tires 265/75-16E so stock is 3,042# ea, and the 265 are 3,415# ea. so in reality my rear axle rating is 6,830#! I base all loading on the VIN plate axle ratings. A lawyer will try to challenge being over GVWR, but over axle ratings I would not want to be in the situation!
Sep-02-2014 06:49 AM
Paul Clancy wrote:
See them every day camping in every campground. Would I feel safe? - no, not at 14k. Having said that I also know the single rear wheel 3500 of the same year is the same truck as 2500 with one more leaf and higher rated wheels and tires and a sticker - so trading for that is a tough pill for the money lost versus some simple upgrades. Personally I'd go to a dually with that weight.
Sep-02-2014 06:48 AM
between .:)
Sep-02-2014 06:32 AM
Sep-02-2014 03:45 AM
between .:)
