โMay-26-2010 10:29 AM
โDec-02-2018 06:53 AM
socaladam wrote:
Not sure what I can do before the repair facility can take the trailer.
โDec-01-2018 05:12 PM
Y-Guy wrote:socaladam wrote:
Today I wiped up water from the leaking roof, pulled the wet bed out and wrote an email to the manufacturer to get yet another warranty issue resolved.
I can't believe my luck is this bad.
Oh no! You have a ATC 8.5x28FB right?
โNov-30-2018 06:15 PM
โNov-30-2018 04:35 PM
โNov-30-2018 11:22 AM
โOct-07-2018 06:28 PM
โAug-24-2018 12:31 PM
โAug-24-2018 07:58 AM
1L243 wrote:
Added backup lights to 2017 Coleman 300tq. I had already added marker lights to the bottom frame below the ramp door.
I found some nice surface mount Led's 18watt flood . I wanted surface mount because i did not want the lights hanging below the frame.
You will need a 7 Way wire harness on your truck and trailer. The center pin will be wired to the backup light on the truck.
On my trailer I only had 6 wires seen plus a metal residential type electrical box that was not waterproof. So I orderd a 7 Way 8' harness with junction box that is color coded.
I fused the yellow reverse light wire with a 5 amp fuse for a 3 amp draw. I did not run a relay.
The lights are bright
Lights up the RV Port well
Cost
Lights $17 each
Harness with box $37
Wire $10
Fuse harness $5
โAug-23-2018 07:22 PM
โJul-22-2018 04:13 PM
โJul-18-2018 09:28 PM
โJul-18-2018 07:18 AM
โJul-18-2018 07:13 AM
โJul-16-2018 06:38 AM
โJul-15-2018 07:21 PM
