What do you cionsider the "best" tow vehicle tire?
1963avanti
Replacing the 245/75/16 tires on my 2005 Duramax. I tow a fifth wheeler with a 1700# tongue weight. I am looking to replace the narrow factory wheels (if necessary). What is your opinion on the best tire for towing with this rig?
29 REPLIES 29
JIMNLIN
I've used the Firestone Transforce H/T on trailer with excellent service but haven't used them on a tow vehicle.
Having five trucks on the road with 16" truck tires I was never a tire brand person.
Most of my tire issues were with Goodyear tires.......but I wouldn't say they were junk. Probably several million Goodyear LT on the road and no issues. I'm looking to put a set of Goodyear Duratrac MT on the wifes 1500 4x4 chevy truck this fall.
I use mostly Cooper/BFG/Michelin/Bridgestone brand tires on my trucks.
IMO whats more important is the right tread type for the job you need the truck to do.
Bowti
Upgraded from 245's to 265 Michelins, like others, I am very happy.
2013 Keystone Cougar 28SGS Xlite
Shipping weight 7561 lbs
Carrying capacity 2439 lbs
Hitch Pin 1410 lbs
2008 Silverado 2500 Duramax 4X4 Crew Cab
Reese 16K Round Tube Slider
Custom 3 Receiver Hitch Scooter Carrier
2013 Honda PCX Scooter on the Carrier
Curly2001
Has anyone tried Firestone Transforce?
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
n0arp
Another vote for Michelin. May be a little more expensive, but you get what you pay for. Toyo would be my second choice.
2000 Country Coach Magna 40',
4380W solar, 22.8kWh LiFePO4@48V, 450AH AGM@12V
2020 Jeep Wrangler Unlimited Rubicon 2.0T, cloaked on 37x13.5s
RAS43
At this point I wish I knew. The OEM Continentals lasted 27000 miles. The replacement Michelins LTX's have 25000 miles on 2 and the other 2 have less as both are replacements for road hazard failures. And the 2 originals have sidewall cracking but the dealer says they are okay ?? They will not make it to 50000 miles even if the sidewalls last. Don't know what will be next so I'll be watching this.
Irish2
Truck came with Firestones and they did not last at all. Tried Michelins and they were good but tried Goodyear Wranglers and was not impressed, so switched back to Michelin Defender LTX and have been happy.
2013 Winnebago 42E
2019 Jeep Cherokee Trailhawk
larry_barnhart
Me Again wrote:
Hard to beat the Michelin Defender LTX MS 2. Chris
have you noticed the mileage is down from the LTX MS 2 to 50,000 from 70,000. We have 4 defenders and 7 LTX MS 2
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Whale1999
X4 Michelin
clotus
Nitto terra grappler G2 for me, but not sure if they make them in 17". I also used the sister company Toyo Open Country AT, both great tires with great max carrying capacity.
Current: 2017 Winnebago 31K
(Sold): 5th wheel: 2015 Heartland Sundance XLT 245
guidry
X3 Michelin
time2roll
Me_Again
caberto
I have the same truck... but mine came with 265/75/16's from the dealer. I upgraded them to 285's and got an unofficial increase in RAWR to 7500 lbs, which I'm nowhere close to in actual numbers. Our fiver tongue weight is only around 2000lbs wet and loaded.
For tire brands (all in AT's), I've had Yokohama, which are nice tires, but too soft. I've had Hankook DynaPro ATM's which were very good tires - lasted a long time, but which I thought were noisy - however, I found out later that all or most of the noise was a bad hub bearing in the front left that I replaced shortly after I got new tires (and still heard a lot of noise). So I'm sure they weren't as noisy as I thought they were. Now the truck's as quiet as it's ever been.
I now have BFG AT KO2's, and they are just as good as the Hankooks. The Hankooks and BFG's I would recommend, they give a solid ride when aired up while towing without hardly any sway to speak of. The Yokohama's seemed to have a lot of flex when towing, and gave an uneasy feeling.
I also have Bilstein shocks that helped improve the stability while towing as well. I highly recommend Bilsteins.
Good luck!
2010 Keystone Cougar 324RLB
2005 GMC 2500HD Duramax/Allison 4x4 Crew Cab S/B
www.imagesbyberto.com
________________________________
WE-C-USA
IMO, You can mount either 245 or 265's on the stock GM rims without any concerns. Once you start looking at aftermarket rims, pay close attention to the backspace.
The choices of 16" aftermarket rims is getting smaller.
Most manufactures are going 18" plus rims.
I recently went to a 16x8 rims with 4.5 backspace & 265's. Haven't pulled with them let.
I've had the 'fat mans' tires and never a problem.
Frank & PJ
2022 2500HD GMC Duramax 4X4
2018 Grand Design-Refection 303RLS
Njmurvin
I got 50K out of my stock Michelins. Then I tried the Hankook Dynapros and only got about 32K out of them. They were a more aggressive tread (which I didn't really need) and were pretty noisy after about 20K. I switched back to Michelins and I love them (Michelin Defender LTX M/S).
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
