What to seal Water Heater with around RV body
scrollmaster
2001 Jayco Quest 5th Wheel, 6 Gal Atwood Water Heater...
Had to remove the water heater to replace cold water shut off valve. It appears that it was sealed with plumbers putty between water heater and RV body, is that right? If not what would be correct material to seal with when I return the water heater into the cavity?
~ the scrollmaster ~
Ford 4x4 F250 SuperDuty 7.3L PowerStroke
2001 Jayco Qwest 24ft
Kipor 3500Ti
7 REPLIES 7
mowermech
butyl rubber tape (the sticky stuff) X3
CM1, USN (RET)
2017 Jayco TT
Allworth
x2 on Butyl Tape. Get it at Camping World and others.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
chipper
Or better yet, butyl tape. It doesn't dry up & come out in a few years.
campingworld.com/shopping/item/butyl-tape-3-4-x30/39160
gene
AVid
RV dealers should have it. Or perhaps your local hardware store too.
John
scrollmaster
Thanks much, will get that.
Kipor 3500Ti
AVid
They use this stuff: Putty Tape
John
Me_Again
That is not plumbers putty. It is a RV bedding compound. Should be available at most RV stores. Chris
