Wheel chock
Jim2007
Hi all; Can the Xwheel stabilizer product or the wheel stop product be used in place of conventional wheel chocks when unhooking or hooking up a fifth wheel trailer? Comments please. Jim2007
TV: 2016 Dodge 2500 Diesel
Rig: 2013 Heartland, Sundance, 5th wheel
20 REPLIES 20
magic43
I have X-Chocks, but I have the rubber wheel chocks on the ground when hitching/unhitching. X-Chocks are best described as "stabilizers".
magic43
Tango__AE7UI
I use both with zero issues!
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
jim1521
Why risk problems for the sake of $50?
Rubber Wheel Chocks
ScottG
I have a set of X chocks. I've looked at this myself and I don't think it would be wise. If you raise or lower the front of the trailer, the wheels actually move a little bit closer or farther apart. Same goes for setting the stab jacks and lifting one side of the trailer slightly.
So you could set the X-chocks in one position and they could get very loose just by making an adjustment.
Old-Biscuit
X-chocks stop back/forth rocking motion BUT are NOT 'recommended' in lieu of wheel chocks.
The two together work best.
Wheel chocks to stop the rig from rolling away and the X-chocks to help with that 'boat on water' feeling
I have used just X-chocks (both sides) on my 5vr but only on fairly level sites. ANY slope for/aft I wheel chock first then x-chock and recheck that evening
Wheel Stop....?
Is that a different product or different description of X-Chocks?
Colo_Native
I don't see why you couldn't. I do know as the tires cool down the chocks either kind will be loose. The standards are easier and faster for setup
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
