I want to use balance beads in my new G614 tires but I do not know which beads to use or where to get them installed. The dynabeads supplier in NY says that I need the larger beads for an RV and they will not go through the valve stem and should be installed by someone experienced with them so as to not get the sealant gunk inside the tire and stick to beads.
Which beads are you using by brand and size and how were they installed? If I need an experienced installer, do you know of one near Houston, Tx. ?
Charles & Elaine Crews, Cindy & Molly - 2 Golden Retrievers
29RLTS '07 Jayco 5th Wheel, '07 Dodge 2500HD, Pullright hitch
