Batteries
rodwha
It seems running two golf cart batteries in a series is the way to fill my two battery compartments (when I get them). I see they run slightly larger than a more typical 12 volt. I assume these fit the standard housings just fine?
I've read good things about lithium batteries. How do these compare?
What are good quality batteries for the money? Any to avoid? I noticed a six pack for just $100 so I assume these are likely not that good as a single lower grade (215 ah) Duracell costs that. How about the Interstate 2300 with 242 ah at 65 lbs? At ~$180/ea I'd feel good about these. Great vehicle batteries.
20 REPLIES 20
pianotuna
Nomad III
Nomad III
A rather interesting graph of the new carbon foam technology!
Regards, Don
pianotuna
Nomad III
Nomad III
handybob is mostly a rant and quite dated.
I chose to get used AGM surplus telecom jars. I'm happy with the results.
Battery selection needs to match the user. A power pole princess needs very little in the way of capacity. A full timer who boondocks needs every watt-hour of battery they can squeeze into the available space. That makes LI and carbon foam chemistries extremely interesting.
carl2591 wrote:
while the lifetime AGM batteries are a good product for sure, but at a cost that is two-three times that of a Wet cell GC battery.
There are thousands of GC batteries in use every day that last 7 or more years. Having worked around golf carts for some years they get a work out every day. With proper charging, which a lot of folks and battery charger manufactures dont know much about, the average battery can go 7 or more years with little issue.
The biggest issue with most RV installed chargers is they do not charge at high enough voltage for long enough to fully charge the battery.This is especially with a lot of solar charge controllers.
If you read Handy bob solar's web you will see what is up with that.
https://handybobsolar.wordpress.com/the-rv-battery-charging-puzzle-2/
In some cases AGM batteries make better sense but for many, me included, good quality GC batteries charged and maintained properly look to be a better deal.
Veebyes wrote:
Installed a 4D Lifeline AGM battery in spring of 2010. Disconnected for the winter last week. Still going strong. 7 years & about 150 nights use per year. Near 6 months storage each year with zero maintenance.
In 7 years you would most likely be into your 3rd pair of wet cell GC batterys.
Regards, Don
MNGeeks61
My 2 cents:
I had an old 2004 golf cart that I sold to my sister in law - at that time, the batteries in it were Trojan T-105's. They lasted 9 years of summer use.
In our newer golf cart, we again purchased 6 T-105's for $120 each installed and load tested. I anticipate they should last 7-8 years as well.
I heard the Trojan is one of the few manufacturers that uses a higher percentage of lead in their plates. But not sure if that's just a rumor.
mchero
I'm with Carl,
I installed 4 Sams Club GC batteries back in 2005 with a new converter, still in service 10 years later. Will be due to be replaced though. Good value.
RM
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
carl2591
Carl2591, Raleigh NC
2005 Airstream Classic 31D
2003 Ford F-250 SD, CC, 7.3L modded diesel machine
Every day is a new day with potential to be life changing.
mchero
Sams Club golf cart batteries if you want longevity. Also, don't forget about what you would do if you needed to replace one under warranty. Pretty easy to find a local Sam's Club or Costco is it not. Yeah, Trojan are good also if want the name.
Robert McHenry
Veebyes
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
EsoxLucius
pianotuna wrote:
The newest kid of the block is carbon foam. It can be taken down to 20% state of charge and offers 1000 cycles to that depth. No sulphation so can be partial charged without damage!
rodwha wrote:
I'm guessing carbon foam is also cost prohibitive like lithium?
$486 for 116 AH Group 31 12 VDC carbon foam AGM battery.
http://www.bruceschwab.com/uploads/2016-firefly-handout-2pg-1.pdf
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
tatest
Not understanding "battery housing" because I just have a tray under the steps and have to drop the batteries into it. I'm guessing you have some kind of a box, and these come in all different sizes and shapes.
Batteries also come in a lot of different sizes and shapes. For nearly equivalent footprints, some of the most popular 6V deep cycle batteries are somewhat taller than the nearest size automotive battery group sizes. But that is just a generalization. You have to measure your "battery housing" and check that against the sizes of available 6V and 12V batteries. Golf cart batteries get you into a whole new area, because 8V batteries are also common for this application, and you can't make those work for a 12V application.
If they can fit, best bargains in lead-acid batteries are flooded wet cells, whether 6V or 12V packages, from discount markets like Sam's or Costco, because they are decent quality at a good price. Second best, or maybe as good a deal, would be from a golf cart dealer, if they have 6V batteries in a size that fits.
Brand doesn't mean much, there are a lot of brands feeding from a smaller number of manufacturers in North America, or a large number of smaller suppliers offshore. For flooded wet cell batteries, I like Trojan for quality, but tend to buy whatever is convenient locally, knowing I'll be replacing it towards the end of the warranty period.
Best quality lead-acid batteries, whether 6V or 12V, and a lot less troublesome, would be high quality AGM batteries, Lifeline being one of the best suppliers. Sears has been in this market for deep cycle, offering more than one grade/warranty period, but I would go with Lifeline if I wanted to put in AGM batteries.
Lithium is a whole different technology. Weight is way down, energy density way up, charging technology is different, and cost per KWH storage is maybe 10x lead-acid or more. Then you have to find package sizes that fit your need, or change your battery soaces to fit what is available. Lithium technology is lately starting to show up as a factory option (more often a special all-electric model) in the RV market, but it is not just replacing lead-acid with lithium tech batteries, it is replacing the whole electrical system and sometimes the whole mix of RV systems and appliances.
Tom Test
Itasca Spirit 29B
allen8106
I installed 2 Crown 240 ah 6 volt batteries. $135 each. Best lead acid battery on the market IMHO.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
rodwha
pianotuna
Nomad III
Nomad III
Regards, Don
EsoxLucius
coolmom42 wrote:
Trojan T-105 golf cart batteries. They will last for many years if you take care of them.
+1
This is where you want to go.
rodwha
I was shown the price for several lithium batteries. WAY TOO MUCH!
We do not have a Sam's or Costco membership (or store nearby).
I wondered, as I don't see anything on having to replace or modify a battery housing to work with the 6 volt golf cart batteries, if they'd work in most any circumstance. Apparently not and something I'll obviously find out about the time I'm back to purchase.
The "six pack" was a deal for six batteries. The price was ridiculously cheap.
