Nov-14-2016 12:23 PM
Nov-18-2016 10:11 PM
Nov-18-2016 08:11 PM
Nov-18-2016 07:10 PM
theoldwizard1 wrote:rodwha wrote:
Reading a bit I see complaining about swapping and getting cheated, but then I also read the same of having them filled. Does anyone place a scale down at fillup?
My local propane filling station has a scale, but they don't use it 🙂 ! That is because they charge a flat rate to fill a 20# tank.
I am not an expert, but I have read that the proper way to fill a 20# tank is to attach the (liquid ?) hose and start the pump. Then open the bleeder valve (screwdriver required). When the bleeder starts to vent liquid (which immediately turns to gas when it hits the atmosphere), close the bleeder and turn off the pump.
Nov-18-2016 07:09 PM
I wouldn't want to swap out new cylinders for an unknown one...
We have a propane business not far from us. I'd go there for now. I wondered about other times such as when you are out all summer, which we are looking forward to doing. The grocery store sure would be convenient... As an aside I'm wondering about filling our grill's cylinder there now that I'm thinking about it, rather than swapping it (15 lbs for about $15). I'll be sure to weigh it just to see from now on.
Nov-15-2016 05:39 AM
3oaks wrote:
They charge the same price to top off a partially depleted tank as they do to refill a completely empty tank.
Nov-15-2016 05:35 AM
Nov-15-2016 03:23 AM
Nov-14-2016 11:02 PM
Nov-14-2016 07:36 PM
Nov-14-2016 06:12 PM
Nov-14-2016 05:27 PM
wanderingbob wrote:
It is not all cut and dried ! The capacity of a cylinder will vary with the temperature at the fill site . Can you imagine the problems with filling a semi-truck with cylinders in New Jersey winter and trucking them to South Florida . fifteen percent expansion is not uncommon . They are trucked all over the nation . Twenty percent of the interior must be left for expansion in swap situations .
Nov-14-2016 04:05 PM
Nov-14-2016 03:45 PM
3oaks wrote:
Some people think exchange tanks are a rip off? Try my local propane supplier.
They charge the same price to top off a partially depleted tank as they do to refill a completely empty tank. I like to start a trip with two full propane tanks. However I always wait until I find a propane dealer that charges by the gallon to refill a partially used tank. Shop local.......not in my home area.
Nov-14-2016 03:30 PM
