1990 P30 454 Chevy Radiator For a Fleetwood Cambria
Yoster
Howdy, this is the 7.4L V8 engine by the way, I'm prepping this fine machine for some long summer hauls, it's got low miles but has aged in the elements and I appear to have a rotten radiator core. The parts store didnt get the correct radiator for the chassis, so I returned it, and the only other thing I can find it being is the CU 308 radiator, which would be difficult and expensive to find. So im also thinking olaboit a recore also. The thing is the CU 308 looks different also, the way thebradiator sits under the cab requires the fill spout to come out of the front and not the top. Any info or ideas would be highly appreciated!
17 REPLIES 17
enblethen
I didn't have any problems getting the correct radiator from O'Reilly auto parts.
Your chassis should be a p-30.
I was able to get an aluminum radiator with more cores then factory. Runs much cooler.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
K_Charles
You have the top and bottom tanks so a radiator shop would be the place to go.
darsben1
YEp, My Fleetwood Southwind appears to have the same radiator. I had to go with a complete new buid of radiator. About $2400.00
You could try workhorseparts.com
Traveling with my best friend, my wife in a 1990 Southwind
