1994 Fleetwood Southwind Specs (especially HEIGHT)
cayuga
Hi,
I'm thinking about driving to look at a 1994 Fleetwood Southwind (35.6'), but I have a 11'3" height restriction and can't find a brochure to tell me if this RV is too high (I found a craigslist posting saying that it's 10'4", but haven't been able to confirm that).
Thanks!
Jeff
7 REPLIES 7
enblethen
Are you sure of heighth at 10'4"? I would say more like 12;4".
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RLS7201
I suspect 10'4" is very close. My 95 Bounder is 10'4" tall at the top of the air conditioners.
Makes little difference weather Chevy P32 with 225/70R19.5 tires at 31.9" diameter or Ford F53 235/85R16 tires at 32" diameter.
Fleetwood gas coaches of that era all used the same body.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
LouLawrence
I would be almost 100% sure it will be taller than 11' 3".
cayuga
Thanks! I guess I'll have to go check it out and measure.
enblethen
My 1993 Fleetwood Pace Arrow on Chev P-30 chassis clearance is 11' 9" with 19.5 tires. Some Ford chassis have 16 inch tireswhich will effect heighth.
I would not truast anything in writing as for heighth. Take a straight board and measure to ground.
I would not use my numbers for your rig either!
Bud
USAF Retired
Pace Arrow
CA_Traveler
And don't assume a 27 year old RV is stock.
2014 Grand Cherokee Overland
Bob
dougrainer
NEVER TRUST A SPEC OR LISTING. The ONLY way to be sure, is for YOU to measure the height. Very few Gasoline Fleetwood would be over 12 foot 6 inches. If any. Doug
