โJun-02-2019 01:27 PM
โSep-12-2019 02:31 PM
โJun-05-2019 09:01 AM
sprintmod1 wrote:
Years ago I had a 2005 American Coach Tradition, basically the same or similar coach.
We had problems with the running lights and right side turn signals not working. Fuses and batteries and relays all good.
There is a big, maybe 2" round, plastic type grommit that goes through the fire wall under the entry steps to the outside front behind the fiberglass front cap.
It is there to make it clean and easy for the wires to pass through the fire wall. What happened in our case is on the outside where the wires pass through the plastic, it gets constantly wet from washing and driving in the rain. Along with the poor roads here in the northeast, the wires corroded and broke. So, sometimes they made contact and worked and other times they didnt work.
We chased that problem for weeks. If I remember correctly, we cut the brown wire marked running lights and the yellow wire marked turn signal, drilled through the plastic grommit and then ran a new through, soldered and heat shrinked it and never had that problem again.
Good luck, I hate electrical problems.!
โJun-03-2019 08:25 PM
โJun-03-2019 07:18 PM
โJun-03-2019 07:45 AM
MyBus2017 wrote:
Pulled every fuse checked, switched relays. Still no running or tail lights. Maybe relay in poplocks security system, only other thing that has to do with lights. Any fuse box found other then drivers compartment nothing to do with running lights. Rear rh compartment engine and transmission fuse box. Back to square 1. Security system might be the problem, hope! Thanks for your input.
โJun-02-2019 09:43 PM
โJun-02-2019 08:36 PM
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
โJun-02-2019 05:15 PM
โJun-02-2019 04:03 PM
MyBus2017 wrote:
Drivers side compartment only fuse panel with light checked all found one blown replaced still no tail or running lights. Itโs a Fleetwood Revolution LE bath and 1/2 model.
โJun-02-2019 02:42 PM
โJun-02-2019 02:21 PM
โJun-02-2019 01:48 PM
MyBus2017 wrote:
Have no running lights. Headlights, dash lights are working. Canโt seem to figure it out.
โJun-02-2019 01:37 PM
