Sep-25-2017 07:31 PM
Oct-01-2017 06:18 PM
roadmooretraveled wrote:CharlesinGA wrote:
On the '06 a critical area is the metal band around the top of the cab at the juncture with the cab over. Use a magnet, if it is steel, RUN. Many have been replaced by aluminum bands and if so, fine, if not, WBO gets lots of money for one, and it will take lots of money to replace it. They rust bad.
We noticed that there is a lot of rust in the area you are describing. The owners state there is no water damage inside the cab, but there was a leak over the rear entry door. We were going to ask our mechanic about this, but is the rust itself a dealbreaker? Assuming we drive it for a year full time in the elements and plan to resell.
Thanks! The post was very helpful.
Oct-01-2017 01:02 PM
Gonzo42 wrote:
One other little thing. Ours has the propane powered generator and later models are diesel powered. I like the propane. Your opinion may vary.
Maybe you don''t like the H floorplan, but we do, and the other floorplans have very small side windows, which sort of belie ther 'View' model name.
As for the sleeping choices, DW needs the firmness of the dinette support. I can sleep almost anywhere, and use either the couch or crow's nest depending on the night tmmeperature.
Sep-26-2017 10:08 PM
Sep-26-2017 06:20 PM
Sep-26-2017 05:39 PM
Sep-26-2017 11:06 AM
Sep-26-2017 05:16 AM
Sep-25-2017 08:13 PM
