How to fix a leak on the dashboard
donnyB7
I am having my roof replaced thanks to hurricane Irma. I also have a leak that made my dashboard wet. I am assuming the rubber extruded seal above the windshield (on the outside) needs to be replaced. I can buy the seal (I have the part number from the Winnebago website) from Amazon, as they sell it by the foot.
Questions:
1) what else will I need when I remove the old seal?
2) I have read that the clearance lights can leak also. What can I seal those up with?
3) I see there is a trim piece on the inside at the top of the windshield that has a few screws holding the trim. Does this also need to come off and be re-sealed? With what?
4) Anything else I am missing?
Edit: Motorhome is a 2006 Winnebago Adventurer 35A
6 REPLIES 6
smlranger
Winnebago had a serious issue with the steel frame behind the windshield rusting badly, which will first cause leaks then will eventually crack the windshield. You can try resealing around the glass but, if you see rust when you remove that rubber trim, the only way to fix the problem is to have the glass removed, the rust dealt with, and windshield installed with new sealer.
Hopefully, your leak is marker lights. Deal with them first and hope that takes care of it.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
Dutch_12078
Probably 75-80% of the dashboard/driving area leaks I've seen over the years have been either marker light cracks/seals or antenna roof penetrations. The others have mostly been front cap to roof seam leaks and not very often, windshield seal leaks.
Dutch
2001 GBM Landau 34' Class A
Hank_MI
Ditto on all the previous responses. I went through this on our MH. First the windshield and the rubber strip. The strip is just for looks. If you pull it off you'll see where the windshield should be sealed to the metal framework. I tried several times to seal the windshield without success. I finally bought some 3M trim adhesive. It's a rubber strip, like tape with adhesive on both sides. I attached that to the back side of the trim piece and reinstalled it. That sealed the trim piece to the front cap.
Still had a leak. Marker light gaskets were shot and previous owner had tried sealing around them with silicone. The water backed up inside the cavity the light assembly sits in and eventually went through the hole the wires come through. I made new gaskets, they're no longer available, from some EDPM weather stripping. No more leaks and it's been in multiple downpours.
K_Charles
The outside molding (120533-01-000) on your windshield has nothing to do with keeping water out, it's just there to make it look good
jplante4
Check your clearance lights.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Home_Skillet
I would have a professional reseal the windshield.
It may not be bonded properly.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
