โDec-17-2017 08:28 AM
โDec-18-2017 07:21 PM
โDec-17-2017 08:52 PM
โDec-17-2017 06:15 PM
j-d wrote:
Rental outfits seem to make little tweaks in the build orders for their coaches. Specifying a BIRD would help make the units a little more Renter-Proof (if that's really possible) by helping keep both batteries up while the renter is on a hookup site.
It'll be interesting to see if retail Fleetwood units are equipped the same. Would be nice if they are...
โDec-17-2017 03:31 PM
โDec-17-2017 02:42 PM
IAMICHABOD wrote:
There are some brands that come from the factory with them already installed,Fleetwood products such as my 2006 Tioga come from the factory with a a Bi-Directional Isolator Relay Delay.
It charges both batteries when either one is being charged. When the coach is being driven, both batteries will be charged from the engine's alternator. When the coach is plugged into shore power,both batteries will be charged from the converter. If neither battery is being charged, the batteries are fully isolated. The controller also
senses heavy loads on either battery to prevent the wrong battery from being inadvertently discharged.
โDec-17-2017 02:00 PM
โDec-17-2017 12:51 PM
ksmoody wrote:
1. Is it better to use something like the "TRIK-L-CHARGE" to charge the chassis battery?
2. When I'm plugged into shore power at home. Is it ok to leave the RV plugged in for a week or so to keep the batteries charged?
3. How often should I check the water level in the batteries?
โDec-17-2017 12:39 PM
โDec-17-2017 09:31 AM
โDec-17-2017 09:28 AM
โDec-17-2017 08:53 AM
