80,000 miles - Automatic Warning Light?
Sourdough_Biscu
I have a class C Winnebago (Chalet). The "Check Engine" light came on almost exactly at 80,000 miles. Is this automatic? I had a Dodge pickup and that happened at 60K miles. (The AUTOMATIC light.) I may call the dealer Monday, but just wondering if anyone has experienced this.
Of course, I'm THOUSANDS of miles away from home. 🙂
It's on a 2006 Ford Econoline Chasis, 450 V10 engine.
Thanks,
Bob
15 REPLIES 15
ReadyToGo
According to Tom and Ray, the check engine light can come on to indicate the problem. If you don't do anything and there isn't a major problem, the next 2 or 3 times you start the engine, and it doesn't see the problem , the light should go out.
The code error is stored, so that if you go to a shop, they can still tell you why it came on even days later.
Now for the horror story. The reason for the info from them was the caller that had the light come on and they stopped. Fortunately for them it had indicated a problem with the alternator which was because the belt had come off. If they had kept on going, the engine would have frozen. You never know.
Bobbo
OP found the problem.
Sourdough Biscuits wrote:
The light has gone on and off a couple times. Finally someplace I could get it checked WHILE it was on. For those who said "O2 Sensor"... give yourself a pat on the back!
Bobbo and Lin
Jim_Shoe
A check engine light at "almost exactly" 80,000 miles sounds more like an automatic warning to do whatever maintenance you're supposed to do at 80,000 miles. Have you checked the manual?
Retired and visiting as much of this beautiful country as I can.
Sourdough_Biscu
Harvey51
I'm one who values a dollar and it took the experience of paying a Chrysler dealer $50 to read a code to make me buy a reader. I find my 50 dollar code reader well worthwhile. When an engine light goes on, it is great to know what the problem is right away.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
noe-place
The check engine light came on in my Crown Vic cruiser and stayed on till my department took it off the street. Never had any trouble and I drove the tires off it. My Vette check engine light came on but I couldn't find any obvious problem so I replaced the gas cap and bingo light went out and has never come back on. Good luck
Bobbo
Too bad you don't have a Scan Gauge II. In addition to giving you access to a lot of information like transmission fluid temperature, it also reads and/or clears the codes thrown when that light comes on.
Bobbo and Lin
j-d
Your Ford chassis doesn't have that feature that turns on a light to say "Bring me to dealer, don't forget checkbook or credit card." The light may go away on its own. Be sure gas cap's tight as noted above.
If you want a parts store like O'Reilly to scan it, NOT California. Rules there don't allow it. I don't know about WA and OR.
Did you drive down Cassiar? What a beautiful ride!
Gene_in_NE
I have a class C Winnebago (Chalet). The "Check Engine" light came on almost exactly at 80,000 miles. Is this automatic? I had a Dodge pickup and that happened at 60K miles. (The AUTOMATIC light.) I may call the dealer Monday, but just wondering if anyone has experienced this....Bob
It could be that it is an automatic notice to do something. I owned a 1995 Geo Tracker that had just that. Mine came on at 60k, 80k, 100k, and 120k. Here is more chatter on mine - Geo Tracker "check engine light". The other suggestions will help you determine that.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
ScottG
It could be automatic. Many vehicles trip the light at 60, 80 or 90K to have you replace the oxygen sensor no matter how its performing.
And unhooking the battery to clear codes is 1990's stuff. A 2006 will have non-volatile memory and it takes more to clear it.
carringb
The E series does not have any automatic reminders. As mentioned there are places to check the code for free. But sometimes be fault will go away on its own and not come back.
2014 ORV really big trailer
2015 Ford Focus ST
buta4
Gretings,
Step One:
Disconnect your battery and then reconnect it.
This will reset the Check Engine light.
Step Two:
If the light comes on again, ask whoever you pick to service your rv to do a Pressure Check on the GAS CAP! That's the cheapest diagnostic test to do. You'd be surprised as to how many worn gas caps cause these problems as the seal is worn down and the pressure valve does not function properly. This leads to several EVAP, etc. error indicators from the on-board rv engine computer.
Step Three:
ALWAYS screw on your gas cap fairly tightly after every fillup!
Believe me...been there ... done that!
If Check Engine light continues, go for full-blown diagnostics as it may be a valid engine problem.
Regards,
Ray
Ray
enblethen
There many Auto Zones and O'reillys depending on your route.
Bellingham several couple on SR 539 just north of Bellingham.
Just off I-5 in Burlington, Mt. Vernon Marysville and Everett.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Sourdough_Biscu
JUST crossed into Suma, WA today. First stop in US since we left home. (Alaska)
