93 Bounder won't move when tranny is in drive position
ybarrabells
Hello. 1993 fleetwood bounder 34' motorhome, 44,000 miles, with a ford 460, and a 4L80E tranny. Driving on freeway slipped once, rpm's raised, thought it had downshifted climbing a hill, immediately released the throttle and reaccelerated and it ran fine for approx 100 miles. Exited freeway to fuel, came to a stop light, when it turned green I stepped on the gas and there was no forward movement, just raised RPM's. Went from"D" to "2" and limped it to the gas station. Fluid is normal in appearance and smell. Reverse, Neutral, 2nd and 1st work. Just not "D". What are your thoughts?
12 REPLIES 12
amxpress
Does it move if you place the shifter into Low? Or Reverse?
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
Gjac
Has the fluid and filter ever been changed since 1993? When I changed mine at 30k miles the magnet inside was loaded. In 24 years and that few miles you may have moisture build up inside. I would drop the pan and change fluid and filter before You expect the worst.
ybarrabells
Sorry. Wrong transmission. Don't know what transmission I have.
wildmanbaker
I believe he meant 4R70 or 4R80. Everyone makes mistakes. All Ford C-6 series should/will start in 2nd, if 2nd gear is selected. Its the programing.
Wildmanbaker
RLS7201
If you do have a 460 engine then you have an E4OD transmission.
Those older Ford transmissions would take off in second when the shift lever was in "2". That would explain why you was able to limp to the gas station. Now you need to find the reason why 1st gear is not working properly. Your torque converter is probably OK. Else wise, you wouldn't have been able to move in 2nd gear.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
KD4UPL
That's the first I've ever heard of a GM trans with a Ford motor. Very interesting. It sound like the torque converter to me. I lost 4th gear once in my '96 Dodge. I was trying to get home so I just used 1st thru 3rd. Eventually I lost 3rd, after a few more miles I lost 2nd. Eventually lost 1st about 1 mile from home. It wouldn't move forward at all. I put it in reverse and that still worked. I backed it home the last mile.
Transmission guy said if I had just let it set after loosing 4th it would have been a much less expensive repair instead of an entire rebuild. Live and learn.
crasster
Sounds like the torque converter (hopefully not). Not a good sign that it works in 2 but not in D. What does the fluid look/smell like? 44k is not impossible for a trans to go, fairly uncommon (except on dodges), but not impossible. There is also age on the trans.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Stranger
4L80E is a GM trans. Don't understand why it's hooked up to a FORD 460.
However, it sounds like the Torque Converter is shot. Seems like lock up went first then the rest. Not a trans expert but I have blown up a few expen$ive transmissions in my day.
Life is not a journey to the grave with the intention of arriving
safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting "Wow, what a ride!".
2012 Mesa Ridge 345RLS
2002 RAM 3500
ybarrabells
Hopefully I don't have to replace the transmission. Which would seem odd at 44,000 miles.
okhmbldr
Sounds like a shift solenoid. Easy to fix but you have to drop the pan.
ybarrabells
That actually is a lot of help. Thank you!!! That's kind of what we are thinking because a transmission shouldn't go out at 44,000 miles!!!
doxiemom11
Probably no help, but our Jeep did that and it was some type of sensor on the transmission.
