AC filter
AikenRacer
I have 3 roof top ac units. I checked the inside coils and they are very nasty. It appears that the cheap sponge like factory filters don't work well. I do keep them clean but too much junk gets by them. Does anyone know of a better quality filter for the roof top units that will work? I may just by a home filter and cut the filter media to fit but just wondering if there are better filters made for the roof top units..
Thanks!
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
6 REPLIES 6
RayChez
I just bought filters at an RV dealer in Las Vegas (Johnnie Walker)and they are only like three dollars. Out of one you cut it in two and you have filters for both air conditioners.
They work pretty good on my air conditioner/heat pump units.
But then again my coach is pretty well sealed and not much dust gets inside the coach. Some coaches have very poor seals around the slides etc.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
chuckftboy
Foam filters don't filter very well so they need to be cleaned often. I wash mine after a week of operation. It does help if you use filter spray which helps with holding the dust and pollen in the filter rather then letting it pass on to the coil.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Old-Biscuit
How often are you changing the foam filters out....??
Yes they are washable but after couple times they begin to stretch
Thin foam material is used because of airflow requirements......if return airflow gets restricted icing can occur on evap coil
Buy a large bag of foam material (ACE Hardware etc) and cut out several filters
Then change out routinely/as needed.....that could be weekly/monthly/bi-yearly just depends on use and environment
Clean dirt ones by soaking in soapy water....rinse/dry/store. Then discard after a few uses.
Foam is cheap..but effective when kept clean and not stretched out
hypoxia
Dennis12
I normally trade my class A in when the filters need cleaned or changed
Dennis Hoppert
down_home
I've got a charcoal filter with finer media openings than stock, that can be cut to fit.
When Coleman repaired our rear ac last of June, I asked about using it. He said they would rather that we sued their filters. Air flow restriction. Gave uss aan email address and they sent us two for free.
W keep our coach really clean inside and don't cook anything that throw off a lot of grease vapor. When we do cook we open the fantastic vent fan too.
I've washed the stock filers ay times over the years a real pain if any grease vapors get into them and it will destroy the material.
I'm not sure what basement air units use but it is time for a redesign for quieter unis with enough filter area for extreme filtering.
The idea was that most RVers didn't take care of things like filters and didn't want problems with the ac from not servicing filters. We need big enough intakes to use the super small micron filters like we use at home, and a filter for the dash air.Lot of junk comes in on a thousand mile trip behind trucks hauling dirt, plowed fields,and such.
Perhaps you can try it and report back. Kind of measure flow from the ac before and after you install it.
