Adding steps to a Class C RV
vj9130
I currently have a 2013 Coachman Leprechaun 319DS which is supposed to have the integrated "step" built into the body/frame of the vehicle. Although it is a bit lower than earlier models, it's still a bit of a reach for my wife with an arthritic hip to step up into the RV.
I was wondering if anyone ever added an additional step to their coach to make it easier to get in/out of? Not looking to add an electric step, just a manual 20-24" step and I haven't looked under the coach for bracing points, etc.
The coach is still under warranty and I don't want to run the risk of voiding that either.
Thank you in advance for any information or guidance.
Vern
5 REPLIES 5
Snowman9000
I can't think of any significant warranty issue you'd have from bolting a sliding step under the frame or body. Should not be a problem. I would think any good RV dealer could handle it.
Currently RV-less but not done yet.
super_camper
Vern
I would go back to your dealer and to Coachmen to find out what happened here. The documentation on the website includes a feature "Integrated Drop-Down Entry Step" and it doesn't sound like you have that on your RV. With the position of the door I can understand the step being too high based on the ride height of the chassis.
vj9130
Bobbo and others, I thank you kindly for the quick replies. I probably should have stated that I did buy a couple at Walmart; they had them over in hardware for $10 each. They are working fine for now, but I was looking into a more "permanent solution. Come to think of it, this may be the best option without drilling holes or voiding MFG's warranties. Thanks again!!
ron_dittmer
We have one for use inside our RV shower. If it is too tall, with a little research it looks like it could be cut on a table saw to your wife's optimal height. Just make sure there is no metal rod inside the hinges.
We bought ours at Bed Bath & Beyond for $10.
Bobbo
How about a folding step stool until you can figure something permanent out? Even after a permanent installation, this step is very useful. We have 2 of them.
Bobbo and Lin
