Aero Turbine muffler?
Slojoe72
Anyone install an Aero Turbine Muffler on your diesel pusher... which one? Happy with sound level? Any added power, or MPG increase?
Thank guys
19 REPLIES 19
Fleet_Man
Inspect the factory installed muffler on your MH before considering replacement with an Aero Turbine straight through version. I considered doing that to mine, see signature, pulled the muffler to inspect it and discovered the factory installed muffler on our MH is a straight through version.
Get underneath with a tape measure, measure the distance from a point in front of the exhaust inlet to the muffler all the way to the end of the tail pipe and extension. Using a plumber or electrician "fish tape," feed it into the tailpipe. if you can feed more than what you measured, you already have a straight through muffler installed. Save your money for something else, no Aero Turbine necessary. That is, unless you actually do need to replace your muffler due to damage, burn through or it is corroded through and leaking.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
TprLSP
Put one on my Cummings 350. Sound was a little deeper but did not seem to be any louder than the stock one. I didn't have any noticeable power or MPG increase.
Larry Mayes
Marrero, la
Fleetwood Revolution LE
Slojoe72
Don't worry guys I won't be disturbing you at the rv parks. I'm only using motorhome to pull my race car trailer to the track and some times stay there… fyi it has a 350 cummins 8.3
Slojoe72
You have one ...... It has to help some. Debbie Downer
1gvols
It's very loud. No to power no to mpg
