Oct-20-2017 01:33 PM
Oct-23-2017 08:21 PM
fcooper wrote:BillofPA wrote:
I had that happen sometimes. I would stop,pull up the knob for parking brake, then push knob down to release the brake and then the alarm would stop.
This sounds like the common Monaco problem of a failing parking brake pressure switch. The switch is manufactured by Nason, and is mounted on the bottom of the knob for the parking brake.
You can probably find additional info on the Monaco Owners forum on the IRV2 site. Some of the posts I saw there had the switch priced at $46 from Monaco.
Fred
Oct-23-2017 10:19 AM
Oct-21-2017 01:11 PM
JaxDad wrote:
Sometimes the answer isn’t to the question you’re asking.
Are you SURE it’s an air alarm? Not an alarm telling you that one (or more) of the levelling jacks aren’t fully up?
My ‘jacks down’ alarm only sounds when you put the transmission in drive or reverse.
Oct-20-2017 07:45 PM
Oct-20-2017 06:50 PM
Oct-20-2017 06:46 PM
KevinE wrote:
Mine will give the alarm when you are in gear and the parking brake is still set as a safety. It will also sound if the brake is released and I'm in neutral, again as a safety. If it's going off when you're in gear and brake released, I'd suspect an air switch on the parking brake that has gone bad. Does the park brake light on the dash go out when released?
Oct-20-2017 06:41 PM
Oct-20-2017 06:40 PM
path1 wrote:EZRider800 wrote:
Path1,
I have 2 needles on the gauge. One red and one green. Both move together. Owners manual says that one needle is for the front tank and one is for the rear tank. I'm getting 120 PSI on the air gauge so the pressure is good. Can't figure out why the alarm comes back on when I put the transmission into Drive?
I am not used to separate needles for separate tanks. So I'm probably not much good to you. But did find this article, not sure if it will help.
[URL]http://www.rvforum.net/joomla/index.php?option=com_content&view=article&id=173:motorhome-air-brake-system-testing&catid=24:tech-topics
Oct-20-2017 05:50 PM
Oct-20-2017 05:32 PM
Oct-20-2017 05:18 PM
Oct-20-2017 04:14 PM
Oct-20-2017 03:42 PM
EZRider800 wrote:
Path1,
Oct-20-2017 03:08 PM
