All DEF fluid is the same right?
StephJohn2010
I was forced to buy a different brand than I usually do.
John & Steph
2012 Fleetwood Discovery 40x (35,000 miles)
380 HP Cummins with an Allison Transmission - Freightliner Chassis
2015 Jeep Cherokee Limited Active Drive II
9 REPLIES 9
Flanz
DSDP Don wrote:
Flanz....Here you go.....DEF
And again....DEF
I guess you could have done this.....
You're correct, I could have, but since I don't use DEF I was just curious and figured someone else had already done it.
Thanks for providing the info. When I do purchase a DP this will be one thing I don't have to go searching for....
-paul
wallynm
All the same except the DEF that I personally produce and then it depends on how much beer I drank for the %age of urea content.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
nevadanick
Light and heat are its enemy. I have ran several different brands in my GMC.
Bob___Ann
Flanz wrote:
Bob & Ann wrote:
It is said to be the same which I believe that it is. What is important is that it is fresh as it does not have a long shelf life. It also breaks down quicker in hot climates.
Is there a date code on the bottle/container? Do you have something that states it breaks down quicker in hotter climates? Please provide a site that claims this since I've never seen this.
-paul
It is published everywhere. Just do a search.
Diesel Exhaust Fluid, otherwise known as automotive-grade urea, is a very stable product with a comparatively long shelf life. According to industry sources:
DEF storage containers from Terra IndustriesDEF storage containers from Terra Industries
โ€ข If Diesel Exhaust Fluid is kept to temperatures between 10 and 90 degrees Fahrenheit, it will last a minimum of 1 year without problems.
โ€ข Big bulk dispensers (1,000 gallons) have internal climate control systems.
โ€ข In cold temperature regions it is recommended to store Diesel Exhaust Fluid in a storage unit. In warm temperature regions it is recommended to store Diesel Exhaust Fluid in a shaded area.
โ€ข New climate control systems specifically for Diesel Exhaust Fluid are being developed.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
DSDP_Don
And again....DEF
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Flanz
-paul
Bob___Ann
Bob and Ann
Autumn-Red Poodle
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
dubdub07
I guess so. I have not had to think about it until now. I just buy the cheapest.
2013 Fleetwood Discovery 40G
TOADS: 12 Jeep JKUR Wrangler, 16 Cherokee Trailhawk, 15 Grand Cherokee, 13 RAM 1500 Longhorn (not a toad) American STEEL = American profits
RET USAF MSGT (26yrs) and still DoD ATC.
DW,DS,DD in the MH w/Westley the killer PUG!
DavisK
It's supposed to be the same to meet government standards. According to my owner's manual, if poor quality DEF is used the driver info center will display the following message:
"EXHAUST FLUID QUALITY POOR - SEE OWNERS MANUAL NOW โ€“ 160 KM (99 MI) UNTIL 105 KM/H (65 MPH) MAX SPEED"
2013 Silverado 2500 HD LTZ CC 6.6L Duramax Diesel
2014 Sunset Trail SF270BH
Holly & Buster, rescued mini Dachshunds
