Apr-09-2014 01:49 PM
Apr-11-2014 04:27 PM
Apr-11-2014 03:54 PM
Apr-11-2014 02:56 PM
JimM68 wrote:
Dexron 3 was a GM standard, but they let it lapse, did not renew it for some reason.
Today, oil mixers can put a dexron 3 label on anything they choose because there is no standard.
I'd never ever use anything labelled dex3, not even to lube door hinges.
Apr-11-2014 11:56 AM
Apr-10-2014 09:22 PM
fredbon wrote:ArchHoagland wrote:
I haven't switched to Transynd because I can get a case of Dexron iii for $20 at Costco.
I do my own changes so it's cheap and easy.
Check out the fluid you are using, Allison has dropped Dextron III from the approved listings, seems the formula has been changed.
Fred
Apr-10-2014 07:13 PM
Apr-09-2014 11:24 PM
bob213 wrote:
There is no better filter than the OEM. Aftermarket seem to have a problem with the placement of the holes, thereby restricting the flow. Look in the Yellow Pages for an Allison dealer near you. We get them for $8.25 at our dealer. They sell the Transynd also. And rgatijnet1 is correct...You are not supposed to "flush" an Allison.
Apr-09-2014 03:44 PM
Apr-09-2014 02:24 PM
Apr-09-2014 02:14 PM
allbrandauto wrote:
wrong way to do it find a shop that has a trans. flush machine and Allison cooler line adapters and have them do it wont cost alot
Apr-09-2014 02:07 PM
