Nov-12-2017 07:37 AM
Nov-14-2017 03:06 PM
Nov-14-2017 02:25 PM
Nov-14-2017 12:06 PM
Nov-14-2017 11:27 AM
Corkey05 wrote:gutfelt wrote:Maybe the OP said it goes into reverse, but the thread title is "Allison will not go in gear". The post is confusing to begin with, but voltage is often overlooked so I mentioned it ... no need to discount any possibility.Corkey05 wrote:
The Allison transmission defaults to neutral at 11 volts. It could be in the charging system, and a low battery. A quick jumper from the house batteries (if at full charge) to chassis batteries, would discount that issue.
Not Low voltage at all as OP says it goes into reverse
as two others have said sounds like the rear Brakes are stuck on
I have had that happen
Nov-14-2017 04:01 AM
Nov-14-2017 03:09 AM
DSDP Don wrote:
Algae won't stop trans from shifting, but the things she's been unplugging and plugging back in could have changed the idle. If the coach is idling faster than spec, (should be around 700 rpm) the Allison will not shift into gear.
Nov-13-2017 08:20 PM
Nov-13-2017 03:15 PM
Nov-13-2017 12:00 PM
Nov-12-2017 07:34 PM
Corkey05 wrote:gutfelt wrote:I see your point, but you fail to see mine. I simply offered something often overlooked. If you read the followup they are now claiming it's engine oil. Like I said the post is confusing so why limit idea's? Why do you insist on arguing? They asked for help, so why do you think yours is the only answer?Corkey05 wrote:gutfelt wrote:Maybe the OP said it goes into reverse, but the thread title is "Allison will not go in gear". The post is confusing to begin with, but voltage is often overlooked so I mentioned it ... no need to discount any possibility.Corkey05 wrote:
BUT as said it goes into reverse so obviously it has 12V power so why bother? that's my pointSeems to go into reverse and move
Nov-12-2017 07:26 PM
Nov-12-2017 04:49 PM
Nov-12-2017 03:46 PM
Nov-12-2017 02:45 PM
