โJun-20-2018 06:44 PM
โJun-22-2018 12:53 PM
Stim wrote:msturtz wrote:STBRetired wrote:
My Onan 5500 will start both my rooftop 13.5K airs at the same time. It does not seem happy about it, but it will start both units. I usually try to avoid that situation.
My QD6000 is an inverter generator. This type has an automatic power protection system that cuts power from the generator if the instantaneous load is too high. This protects the generator from a too high a load and the RV components from voltage sags. A non-inverter generator such as the gasoline models do not have the inverter capability and lack the instantaneous power overload protection. Instead, they rely on a breaker which takes a while to trip which can allow a large drop in voltage and a major load on the generator engine. What actually happens is the speed dramatically drops. Non-inverter generators generally run at 3600 RPM and the frequency of the output is directly tied to the RPM of the generator. the problem of a large load is the voltage sags due to the load and at the same time the RPM of the generator slows down dropping the frequency from 60 HZ to some other frequency. None of these things is good for the generator or the motor running the generator.
โJun-22-2018 12:18 PM
kmb1966 wrote:LVJ58 wrote:
There must be some reason your coach came equipped with a 7000. If it were my coach I would replace it with a 7000 even if it cost more. However it's your call.
Good luck and safe travels....
I spoke with Winnebago today. They called up my serial#. Apparently it was totally the purchaser's decision(the unit was special order from the "ability equipped" division). For some reason the purchaser went with a 30amp coach, but upgraded to the Onan 7000k unit. But with basement a/c, and 30 amp EMS, there really isn't much of a way to utilize the 7,000 over the 5500. Limited to 30 amps. So Winnebago said, just replace with 5500 because the 7,000 would be a waste of $. If it were a 50 amp unit, it would be altogether a different situation.
โJun-22-2018 07:13 AM
โJun-21-2018 09:15 PM
โJun-21-2018 08:13 PM
โJun-21-2018 08:09 PM
A Good Cigar wrote:
KMB, do you live in an area with very high summer temps? I have an Onan 5500 watt in my 2000 Suncruiser, and being in the Phoenix metro area with zero chance of seeing freezing temperatures, I run straight 30wt oil in it. Several summers with it running during the drive in temps well over 100ยฐ and no hiccups. I can't imagine that your 7000 watt has to even break a sweat to power a 30 amp coach! If it was a 50 amp coach it would also have the 7000 watt option, and the same cover and ventilation, so I'd be concerned about the replacement generator having the same problem!
Is code 37 for overheating?
โJun-21-2018 07:34 PM
โJun-21-2018 06:12 PM
โJun-21-2018 04:54 PM
fred42 wrote:
kmb1966,
I have the same 7k unit in a 2007 Allegro. I have no vent in my bin door either. Was there something special about your installation that requires a vent for cooling?
thanks,
โJun-21-2018 04:53 PM
โJun-21-2018 11:47 AM
โJun-21-2018 11:44 AM
โJun-21-2018 04:51 AM
msturtz wrote:kmb1966 wrote:msturtz wrote:kmb1966 wrote:
My 2001 Itasca Suncruiser has an Onan Marquis Gold 7000 generator. Started giving a code 37, brought in to the Onan service center. Service center says debris in the engine, bent rocker arm, burnt valves, some damage to excessive HEAT. Despite all of my religious oil changes, exercising, filter changes and only 750 hours, the unit will cost over 1900 to repair. Can't see spending that much money on that old of a unit. Also, I never understood why the unit came with a Marquis Gold 7000, when a 5500 appears able to do the job. My unit has basement A/C where the 20 amp circuit is tied directly to the 1st compressor (pulls about 12 amps) and the 30 amp circuit is tied to the EMS 30 amp system for the 2nd compressor and the rest of the unit. The Onan 5500 would appear to be able to handle this setup fine, and the Onan 7000 produces more power, but I don't see how I could utilize that extra power with the way it is wired. New Onan 5500 is around $4,000 and a new Onan 7000 is another $1,000
I suppose I am going to go with a new Onan 5500 with new warranty. Onan service center says it can solve the heat problem with a modification to the bin door with a louver/vent and a heat shield. Still trying to get details before I pull the trigger on this deal. Opinions welcome. Thank you in advance.
I would hazard a guess that you coach is wired for split phase 240 which is 120 per leg to neutral. We have a QD6000 that will not โstartโ both our 13,000 BTU ACs. The problem isnโt the running load itโs the start load. Starting two ACs even with a hard start capacitor is iffy with any generator less than 7k. Add to that it is very common for there to be other loads such as the converter refrigerator etc. if nothing else is on and I stagger the startup sometimes I can get both ACs running. Most of the time the generator overload protection system dumps all the loads. On one trip I forgot to turn off one AC and AGS started the generator and the first AC started but when the second one tried to start all the power went off from the generator. Bottom line is start loads will strain a generator even if it is able to start them.
Thank you for the feedback. My unit does not have 2 a/c units. It has basement a/c with 2 compressors. First compressor comes on and then if it cannot bring the temp down, the 2nd compressor comes on to assist.
Hmm... I have never heard of such a configuration. If I were to guess each compressor has its own condenser and evaporator by definition would function like two ACs would at least in current draw. The only difference would be the lack of an additional blower motor. A blower motor isnโt much of a draw compared to the compressor motor.
โJun-21-2018 04:49 AM
