awning
bsport
Awning over door was going in then stopped and something awning snaped out will not retract, motor runs but awning will not move. Any idea as to what broke,and how do I get it closed. 2002 Mandalay
3 REPLIES 3
NorCal_Dan
Had the same happen to mine. I removed 2 screws and removed the whole thing. My dealer replaced the motor inside the awning tube. Said the original motor had nylon or plastic gears, the replacements now have metal for the gears.
'13 Ram 2500Hemi pulling '12 Coachman Chaparral -- USAF Retired --
bsport
UsualSuspect wrote:
Is it an A&E? My A&E did the same thing a few months ago. You need to get some zip ties, a ladder, and a second set of hands. Wedge the zip ties before you roll it up on each end of the awning. Someone will need to slowly push the awning in while the other person pushes the button to close it. Once closed, zip tie each end. It will hold until you can get to a good spot to fix it.
The part that you will probably need is similar to End Cap. Before you order it, make sure you verify that is the part as they changed it slightly in other years. You will need to get the model number and download the parts guide. IIRC the part with shipping was around $120.
Thanks will look at it as soon as it stops raining .
bsport
UsualSuspect
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC (Yes, it is my TOAD :B)
2011 Toyota Tundra
2013 Jeep Wrangler Unlimited Sahara (Backup towed)
Gone but not forgotten, 2008 Jayco 299 RLS
