Basic questions about Class B's
Gjac
I notice most class B's have small FW tanks and very little storage. For those that dry camp how do you carry extra water? Also are there any class B's made with a slide and some kind of basement storage?
43 REPLIES 43
Songbirds
Ed_Gee wrote:
A class B is essentially a modified van chassis.....so no under storage to speak of and certainly no slide. The next step would be a small class C which would be a manufactured coach body placed on a CUTAWAY van chassis.
Here is a 2016 model with all that your asking for but is a class B+ Here is a link. 2016 Renegade good luck
2021 Mercedes-Benz Sprinter Van, showing six tires down, 3400XD, V6, 7-Speed Automatic 24FL, 170-WB, 24'-3", Coachmen Galleria w/Li3, "Next ROAD TRIP" to where?
Gjac
Trekkar wrote:
pasusan wrote:
It can actually be fun to figure out how to camp with limited water/storage....
We bring a few gallon jugs of water stored under the bed for cooking and possible emergencies. We don't bring lots of unnecessary stuff to set up camp - no pink flamingos, etc...
X2 Most of our camping is boondocking, and we can normally go about a week. We go to enjoy what's out there, not set up house. The 'B' has been perfect for us.
Do you carry extra water with you? I see the 190 has 31 gals of FW. Do you use wood block to level your 190?
Gjac
bob_nestor wrote:
That depends on the model/manufacturer. I had a Roadtrek 210 Popular which is a Class B and it had quite a bit of outside under storage. About 1/2 my camping was dry camping with it and I could go about a week between dumps and water fill ups; 3 days when I was camping with a friend. One just needs to adjust to the storage available. Coming from tent camping I found the storage quite adequate and I actually camped comfortably a couple of summers in it. My general rule is if I have something in the RV that hasn't been used in the last 3 camping trips, it's not necessary and it comes out of the RV.
I just looked at that model online, 36 gals of FW, 1400lbs CCC, 7000 lbs tow rating and 1000 lbs tongue weight. Those are good specs for a 21 ft B. Also someone mentioned to add a rack in the back receiver for extra storage with 1000 lbs tongue rating that is a lot of stuff. I did not see the outside under storage on the 2020 model. hard to tell from their pictures. 60 gals of FW last me and my wife 7 days so I can live with 36 plus a 4 gal container in that B.
magicbus
patperry2766 wrote:
Jayco
I think you might be able to expand your options in a small class C. Really not much bigger than a class B but you'd be able to get a slide
You can get a slide in a B from Winnebago but it does block access to the rear of the coach when not deployed. Quite frankly, having had slides, itโ€™s nice not having one :). No slide getting stuck worries and fitting into normal width parking spots is pretty cool.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
Trekkar
2014 Dodge Ram 1500
2021 Salem SFX 167RBK
bob_nestor
wildtoad
Get a rear hitch mounted storage box. Can store stuff and some water. Donโ€™t overload it.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
patperry2766
Jayco
Courage is the feeling you have right before you fully understand the situation
steveh27
My 1997 Xplorer 230XL has a 25 gal fw tank. I usually boondoack a lot. I do carry 2-4 gallon jugs of water in the van. I camp alone so use less. I can last up to a week. If not I find a place to refill.
rexlion
Camping out of my cargo trailer, I've discovered that dish washing and rinsing can be accomplished with a very small amount of water. A plastic collapsible water container with small spout dispenses water slowly, pretty much in dribbles. Even the blue Reliance Aqua-Tainer spouts can be opened just partially for low water use. There's hardly any comparison between that and an RV water pump which throws way more water than necessary out the faucet.
"Navy" style showers (low water use) are another strategy. My porta-potti doesn't need much water for flushing, and the reservoir holds enough flush water for about 5 days. Of course, the other main uses I have for water are drinking and cooking, and for those I don't skimp.
Between the water containers in my cooler and a pair of Aqua-Tainers, if I'm careful I can boondock for just about a week.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
magicbus
Depends on how long between visits to civilization. We are good for a minimum 4 days completely on our own. Our fresh water and gray are no problem for more but our black limits us (unless weโ€™re in the woods). Power is no issue as we barely use electricity when camping. A bit for LED lighting and to light the fridge. As for storage, we have a decent fridge and a relatively good deal of accessible storage under our rear bed.
Dave
pasusan
Susan & Ben [2004 Roadtrek 170]
href="https://sites.google.com/view/pasusan-trips/home" target="_blank">Trip Pics
Lwiddis
I mostly boondock and rarely see a B doing the same. Just not built for it.
Ed_Gee
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
