Basment air
cableguy574
Besides cleaning the filter is there anything else needed to be done to basement air for maintenance
2008 National Pacifica V36a
2014 Jeep Wrangler /Brake Buddy
JUST Me & My wife & dogs ๐Ÿ™‚
FMCA 387898
A member of NUTS
6 REPLIES 6
J-Rooster
427435 wrote:
chuckftboy wrote:
one time every year the coils should be inspected and cleaned if needed.
the condensate pan should be flushed with clean water.
all elecrtical connections should be checked for tightness
check the fan blades for cracks or loose rivits. clean them if needed
there are some steel parts that if showing signs of rust should be wire brushed and touched up with rustolium paint
I'm not sure there is a condensate pan on a basement air----condensate water just falls on the ground.
X-2 this is how mine works!
Wizard_1946
X2 on checking the rubber drain. It has a rubber tab on the bottom, just wiggle the tab back and forth.
Jerry
2000 Journey 36G
2006 Explorer 4X4
Nothing I've got to do and all day to do it :B
RCtime
correct Mark
Just make sure the rubber drain is not plugged.
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2013 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel, RIP
TT/N
427435
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
chuckftboy
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
maanpaontheroad
Keep air passage clear and clean outside grill free from bugs etc.
2007 Suncruiser 38T
2004 Rubicon
FMCA F394282
:R
