Battery Disconnect Switch
sew0177
I want to install a battery disconnect switch on my 04 Revolution but want to make sure it can handle the amperage generated by the 4 house batteries. I have searched the board and found information about using disconnect switches but not the size or type.
Any suggestions?
19 REPLIES 19
Hikerdogs
You might want to look at Flaming River products.
http://www.flamingriver.com/index.php/products/c0015?gclid=CP_2q5Dy78kCFdgHgQodztEKYA
Their larger switches can handle 2,500 amps of cranking power. We used one for over 12 years on our 2001 Winnebago Adventurer. We didn't need one with that high a power rating, but did like the mounting brackets and solid connections. They aren't cheap, but they will handle just about any load you throw at them for may years to come.
Hikerdogs
2013 Winnebago Adventurer
Sam_Spade
enblethen wrote:
Remember that you should not be connecting or disconnecting under a heavy load.
Absolutely right. As near to zero as possible. But the switch must be capable of carrying the same load as the main cables.
The circuit to the inverter if equipped should not be going through the disconnect.
That last comment is confusing and, I think, wrong.
A battery disconnect switch should disconnect the batteries from EVERYTHING.....except a battery tender (solar or otherwise) that you want running all the time.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
DrewE
What loads are you switching? You need to size the disconnect switch for the current the load consumes, not for the current the battery could theoretically produce. Your battery can producing a short circuit current that's a lot higher than should ever be possibly required of it. A lead-acid battery is capable of doing things like melt wrenches that are accidentally dropped across the terminals.
If you're switching the main input to your 12V distribution panel (only), you'll never be switching more than the main fuse there or, if it has no main fuse(s), the sum of the branch circuit fuses. Typically this would be on the order of 100A or so, but it could vary depending on the RV and what all devices it's equipped with and how its wired.
If you have a nontrivial inverter you're running through the disconnect switch, the current rating needs to be a lot higher.
enblethen
You didn't say whether you wanted an electrically or manually operated. Surprised that your rig is equipped with battery disconnects.
This unit from Intellitec should handle your needs.
Intellitec Big Boy
Remember that you should not be connecting or disconnecting under a heavy load. The circuit to the inverter if equipped should not be going through the disconnect.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wolfe10
Marine ON-OFF switches will do what you want. Here is one rated for 450 amps continuous, 1,200 intermittent.
http://www.perko.com/catalog/battery_switches/99/heavy_duty_battery_disconnect_switch/
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
