Mar-21-2021 05:09 PM
May-06-2021 08:08 PM
Bordercollie wrote:
It would be good if RV manufacturers would include a placard that clearly states this kind of information including location of solenoid switches, fuses, reset buttons, etc. The proper operation of generator, converter/charger, transfer switch, chassis alternator, house and chassis batteries, etc., is critical to running air conditioning, furnace, fridge, microwave, water heater, interior lights, fans and entertainment devices.I wonder how renters figure this stuff out once the are out on the road.
May-06-2021 07:42 PM
Apr-17-2021 07:30 PM
Apr-16-2021 07:20 AM
Harvey51 wrote:
Slightly off topic, sorry. I set up an alarm for the house door steps that rings when the engine is running and the steps are down. Unfortunately it quit working and I’m having trouble fixing it. I initially found a fuse in the fuse box under the steering wheel that provided 12 volts only when the engine is running. Anyone have a fuse chart to help me find it again? A few years ago I posted the whole thing in this forum. I would appreciate a link to it.
Apr-15-2021 09:05 PM
Apr-03-2021 06:18 AM
Bud
USAF Retired
Pace Arrow
Apr-02-2021 10:01 PM
enblethen wrote:
The Cole Hersee style 200 amp is normally stocked at NAPA.
Apr-02-2021 09:49 PM
coolmom42 wrote:
I'm thinking that POSSIBLY the generator starts off the chassis battery--because one day I couldn't get the generator to start (think I just didn't prime it enough the first time) and cranked it multiple times with no luck. Then the chassis battery turned out to be dead, as in it wouldn't start the vehicle. As soon as I got the chassis battery jumped, and the engine going, the generator started right up.
So my thinking was that I ran the chassis battery down in attempts to start the generator. Still not sure if that's what happened.
Mar-28-2021 05:21 PM
Mar-26-2021 02:24 PM
time2roll wrote:
I think I would prefer the generator starts from the chassis battery. Only trick is you need to make sure when the generator is running that the chassis battery is getting recharged.
Mar-26-2021 02:04 PM
coolmom42 wrote:I think I would prefer the generator starts from the chassis battery. Only trick is you need to make sure when the generator is running that the chassis battery is getting recharged.
Mar-25-2021 10:30 PM
Mar-25-2021 08:35 PM
Mar-25-2021 08:20 PM
