Bedroom Slide won't Extend
mmccray100
Regarding my 1999 Winnebago Chieftain using HWH Series 200 hydraulic leveling jacks with 2 slides.
I was parked for a week before making a propane run. The slides and Jacks retracted normally. When I returned, the levelers worked per normal and living room slide extended. The bedroom slide went out about 12 inches and stopped. I retracted then tried to extend again but no action at all. I don't hear the pump, only the switch clicking.
I'd had a problem retracting both slides back in March. That turned out to be caused by low fluid. I checked the level this time. It took 1 1/2 quarts, but I'm still unable to extend the bedroom.
I've got the switch exposed and will check it. But first I decided to call HWH. They said they are very busy and it would be a week before someone would call me back!
So now I'm reaching out to rv.net folks. l'v received great help before.
TIA
Mike
11 REPLIES 11
mmccray100
As I reported yesterday, the problem was the Chassis Battery. I replaced it and all is well.
I have the original HWH manual and nowhere does it caution about completing extension before retraction.
Mike
mike_brez
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
FIRE_UP
TIA
Mike
Mike,
Well, since no one's commented on it, I'll mention it. You state you had to add "1 1/2" quarts? Wow, that's a pretty fair amount of fluid in my book. The reservoir on most coaches for the two systems is not all that big so, 1.5 Qts. is a lot. You don't mention a leak, puddleing, or seeping anywhere. We have a similar system on our '04 Itasca Horizon 36GD with the C-7 330HP CAT.
On occasion, it too will run the bedroom slide out about 1/2 way and quit. Now, in my HWH manual and, the owners manual for the Itasca both state that you SHOULD NOT extend either slide a partial amount, then retract them. It states to EXTEND EITHER SLIDE, TO FULL EXTENSION AND THEN, RETRACT IT. And, it goes for the retraction too. Fully retract either slide, THEN extend it. You can, in semi-emergency conditions, go the opposite direction of what you're doing, if you're only 1/2 way in or out but, it's not recommended.
Anyway, on yours, if you're not hearing the pump, sounds like you're not obviously getting juice to the motor. Other than to tell you to start back tracking the flow of electricity to find out where the issue is, not sure what else to advise you here. Good luck.
Scott
I guess they are all different. I'm not in front of my HWH manual right now but I could swear that it said to move it in and out six inches or so to adjust.
Mike,
I have parts and service manuals for the levelers but, I can't find any right now for the slide operation. It was in my owners manual for the Itasca where it stated to extend or, retract, for the entire travel of the slide, before reversing. I'll dig that up tomorrow just to make sure I'm not producing bad info.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
mike_brez
TIA
Mike
Mike,
Scott
2015 Wrangler JKU
mmccray100
Problem solved. It was the Chassis battery. Just replaced it and everything is working fine.
As for the amount of fluid, yes I put in 1.5 quarts. I cannot see a puddle anywhere, so I don't know where it went. When the RV tech added fluid, 2 months ago, he put in 1 quart. I don't know if that filled it up or not. He used my fluid and I had only 1.
In a week when HWH gets around to calling, I'll ask about the fluid level/capacity.
Thanks for all the replies.
Mike
FIRE_UP
TIA
Mike
Mike,
Scott
Scott and Karla
SDFD RETIRED
KI60ND
horizon36
I had a similar problem, maybe. When trying to move the slide do you hear the pump running, but are getting little or no movement? If so, it could be a defective shuttle valve. I took mine to a trusted service shop and that's what HWH diagnosed with the tech over the phone. Replace the valve and all is good.
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
bluwtr49
A couple of the most common causes would be a bad switch, bad relay, or trip Circuit breaker our fuse which you coach uses.
Our coach uses self resetting circuit breakers and when I had a similar problem, it drove me nuts until I replaced both the CB and also the relay.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
rgatijnet1
While you try the slide switch, also switch on your "battery boost" switch to add those batteries to the circuit.
If you do not hear the pump running, it is not low on fluid or have air in the system. It is an electrical problem.
1995brave
Have you gone to the HWH website and downloaded the troubleshooting guide for your series jacks?
www.hwh.com
mabynack
It could be air in the system. Cycle the slides several times to work the air out. The other things I would consider are low battery voltage. Pull the battery and have it checked for a shorted cell. Another possible cause is the solenoid. The contacts inside the solenoid can get dirty. The solenoid will still click, but the contacts won't let enough current pass to operate the slides. Check it by installing an amp gage between the solenoid terminal and the pump.
I'm having the same issue with my FW. I just haven't had the time to deal with it.
