Best Paint for Battery Compartment?
subtroll
After 10 years of inattention, I'm in the process of restoring the battery compartment in our coach. It has two Kwikee slide trays for the 4 coach and 2 engine batteries. The slides are badly corroded and the compartment walls are badly rusted.
I've removed the batteries and trays and plan to rebuild one and replace the other. Now I'm cleaning, wire brushing and preparing to repaint the compartment walls.
I'd like to locate a two part Urethane or Epoxy paint but other than garage floor paint in expensive gallon cans, the best I can find is Rustoleum Epoxy Appliance paint. Any suggestions?
2004 National Tropi-cal Sterling 396
2003 Jeep Liberty
15 REPLIES 15
deltamaster
rgatijnet1 wrote:
First use a baking soda solution to completely neutralize any acid that got in to the compartment. Then use the proper epoxy primer. Afterwards I would use a paint specifically formulated for battery compartments. Acid proof paint
When I was in the Air Force as a mechanic we used that stuff on all the vehicle battery boxes. It seemed to wok well when applied liberally. That is what I would use.
:E [purple]I ride it like I stole it![/purple] :B
.......and I just may have.......
I'm on "CB-13", are you?
2004 Fun Mover with a 1998 Road King and a 2002 Sportster tucked in the garage, Dragging a 2002 "RAM Tough" Dodge Dakota Crew Cab. Ohhh what a haul!
TSgt(Ret.) USAF
stripit
two travelers wrote:
I redid my battery box last year. First I cleaned it with baking soda several times. Then, I used the POR-15 cleaner, then the paint. After a few months, the POR-15 was peeling up. I sanded it real good put Rustoleum on it then found a plastic battery tray that held the batteries and, no more problems. Don't know what happened with the POR-15 but it was terrible would never use again.
I have things that are coated with POR-15 that have lasted over 15 years, still looks like it did when they were coated. If it peeled off it didn't bond. If it didn't bond it wasn't clean well enough. Not that you did anything wrong, but the stuff will stick when the surface is good enough to let it work.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
two_travelers
stripit
POR stands for paint over rust and it does exactly what it was intended to do. It is a 1 part air dry epoxy that sticks to everything it is applied to if properly cleaned first. Be sure if you use it to wear long sleeve shirt and gloves with eye protection. You will NOT wash any overspray off. If you opt for the sliver color and it gets on you, you will look like the Tin Man for a week or more. Don't ask...
Stacey Frank
2019 Tesla Model X
okgc
Another vote for POR-15
2010 Tiffin Allegro RED 36 QSA with GMC Envoy
Alaska 2015
n4hwl
I used truck bed liner spray in a can and I liked it. I think I got it at wall mart but a better quality could probably be found elsewhere
Ken
2014 Tiffin Zephyr
powderman426
Tom/Barb wrote:
we removed the trays, had them bead blasted and powder coated. our compartment walls were not corroded so we sprayed them with CRC corrosion preventive. when the batteries went in they sat on a 1/2" layer of baking soda. the whole compartment gets washed and cleaned every 6 months.
This is the best approach, but many do not want to take the time and trouble. Epoxy is best, but eurothane is good it it will be in sunlight.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
DSDP_Don
Another vote for POR. My previous coach came with a large sheet of plastic (about twice the thickness of a place mat) covering the battery tray floor. It worked well and was easy to clean.
It sounds like you're doing a nice job rebuilding the compartment. When you get done, you might think about adding the ProFill automatic watering system. It's battery caps seal the batteries and keep the acid down. It also makes filling the batteries a breeze. You can check/fill all batteries in under 5 minutes.
I'm sure you diagrammed your batteries when you removed them, but as a safety precaution, I like to reconnect everything and before I add the ground cable, I put a volt meter in line and check that I'm at 12 volts, not 6 or 18.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Sully2
I used POR-15 on my own 2 years ago. Looks great
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
RoyB
I have sprayed a rubber based paint around my battery trays etc with good success too...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Tom_Barb
Victhedude44
Another thing a boater friend told me is to set the batteries on a rubber pad and much less or no corrosion.
Twomed
2x. POR15. Dries to solid glass like finish. Kills any existing rust.
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
23hotrodr
I have had great success with many battery compartments in RVs, autos, and golf carts, by preping as previously suggested and then coating with POR-15 paint or Loctite Extend rust converter. Then I top coat the entire area with Dupli-color Bed Armor truck bed coating. This is easy to do and lasts a long time.
2007 Itasca Suncruiser 35L
2000 Jeep Wrangler
