Jul-04-2014 02:59 PM
Jul-05-2014 06:58 AM
mike brez wrote:thats great!!:B you know you can retro fit a seat on those and they do make easy rid liners too
We use this. Easy to dump and rinse.
Jul-05-2014 06:56 AM
JimM68 wrote:and is 900-1100 dollars..ouch
If you have power nearby and can handle the retrofit, I really like our Thetford Techma. It is an electric toilet with a "house style flush" and a builtin macerator.
Totally eliminates black tank problems, no more poo pyramid. Nothing solid will ever get into the black tank again.
Downside is it uses a lot of water.
Jul-05-2014 06:04 AM
rgatijnet1 wrote:
I prefer the Dometic 320 toilet because of the extra height and the elongated bowl/seat.
Jul-05-2014 05:58 AM
Jul-05-2014 05:40 AM
Jul-05-2014 05:35 AM
Deano56 wrote:
i replaced our old Aqua Magic plastic toilet a couple months ago and went with the Dometic 311 low profile(same as 310 only bone color).I bought a 1/4" riser from the hardware store, turned it to the 3 and 9 o'clock position, siliconed and then screwed to down. Waited until the next day to set the toilet and all is fine. The gasket will compress a little more than usual but still seals. I know one person that heated up a spare toilet bolt enough to push the bolt through the flange around to the correct position. It's doable either way, the other mentioned toilets are fine but not for the budget minded IMO
Jul-04-2014 08:09 PM
Jul-04-2014 06:39 PM
Jul-04-2014 06:30 PM
Popsie wrote:
We replaced our standard issue RV toilet with a solid china Concerto toilet eight or ten years ago. It's very sturdy and comfortable to use.
We've been very happy with the Concerto - it's more like home.
Jul-04-2014 06:15 PM
Jul-04-2014 05:37 PM
Jul-04-2014 05:33 PM
Jul-04-2014 05:07 PM
Jul-04-2014 04:36 PM
Jul-04-2014 03:20 PM
