โMar-04-2016 07:43 AM
โMay-06-2016 05:53 PM
j-d wrote:
Glad the shocks helped. With only the possible exception of the new Koni FSD's, every shock I've read about has its fans and its detractors.
Weigh it and adjust front tire pressure according to actual scale weight.
Check for looseness (steering wheel play) in the steering gear box.
Be sure the fiber coupling from steering shaft to gear box isn't worn out.
Check four bushings. Two at inner axle ends (where they mount to cross member), and two where radius arms mount to chassis rails.
Be sure the front wheels are Toe IN (1/8" to 1/4") but absolutely not OUT. Sounds odd, but with the Toe corrected, the steering had much less of the "loose" feeling. I could sense improvement before I even got in the freeway.
Your chassis has a Kingpin Front End, not Ball Joints like later ones. I doubt the kingpins are worn out, but...
Do check for looseness in the rest of the steering linkage components.
Your chassis has the potential to drive better than the newer ones.
โMay-03-2016 05:22 PM
โMay-03-2016 04:12 PM
pnichols wrote:monchichi6 wrote:
Spoke to Koni and they do not make shocks for the '89 year.
Hmmm ... I wonder what's so different in the suspensions between a 1989 E350 and a newer E350 such that the current Koni FSD shocks for E350 models wouldn't just bolt right onto a 1989 E350?
I'm not sure that what the Koni rep told you is true in an absolute sense. They might have been merely quoting their published literature on what E350 models their shocks have either actually been tried on or been dimensionally verified on for Ford E350 suspension drawings from later than 1989 models.
Unfortunately, the current Koni FSD shocks for the E350 just might have fit fine on your 1989.
โMay-03-2016 04:09 PM
j-d wrote:
OP - When we had a 1984 24-ft rear bath Class C on E350, it wasn't older "then" than yours is "now." By then I mean when we added a leaf to the rear springs. The leaves were called "Repair Leaves" and are sold by thickness and width. Have to be cut to length, and they do NOT come with a Center Hole. It all went well except drilling for the Center Bolt. Spring shops have an "Ironworker" machine that can punch the holes. Even shear the leaves down to correct length. Shop we bought our leaves from said their machine was down. Maybe they wanted to punish us for not using them for the whole job... We bought a special bit at a commercial tool supply and barely drilled the two holes (one each side) before the bit was shot. The Length can be adjusted with Torch, Carborundum Blade, maybe even Bi-Metal Hacksaw.
Our 1983 chassis was 18 years old/90000 miles when we got it. Rear sagged slightly and the Leaves were a huge improvement. I think we spent about $175 on parts back then. Leaves, Center Bolts, U-Bolts, Drill Bit. Another huge improvement parts-wise was new hard plastic end link kits for the OEM front sway bar. We never did the center bushings and never added anything at the rear but those leaves. The other "Big Thing" was we found the TOE was Way Out and set it to a Little IN. Another huge difference.
I did a few other things but those improvements were incremental not dramatic like above: New Front Axle Bushings (Axle to Frame, Radius Arm to Frame), Rebuilt Steering Box (mostly because ours was leaking), New Front Shocks from CarQuest (probably re-boxed Monroe Magnum Gas RV shocks).
I decided a previous owner (we were fourth) had changed rear shocks but not fronts. They were NOT all that hard to change. The 1992+ is much more difficult.
I tried to find a listing/pic of a "Repair Leaf" and all I found was complete spring packs. Made me wonder if "Helper Springs" like might do same as adding a Repair Leaf. The Helpers are designed for DIY installation, but I just don't know if the outcome would be as good as an additional leaf right in the pack. I DO know that there might be clearance/interference issues in a motorhome installation. Lotta stuff under there!
โMar-07-2016 02:28 PM
โMar-07-2016 01:37 PM
โMar-07-2016 12:07 PM
โMar-07-2016 11:29 AM
โMar-06-2016 02:57 PM
โMar-06-2016 01:26 PM
โMar-06-2016 12:10 PM
tpi wrote:I am also unimpressed by someone saying I put Brand X on and I cannot believe the difference. Replacing old worn out shocks with even the cheapest Chinese junk will make a huge difference!
This is a valid point but I want to insure it isn't applied to my experience. The Ford shocks I replaced with superior Konis had about 12K miles on them and were performing as new. Loose shock control was noted from the first.
โMar-06-2016 09:04 AM
โMar-06-2016 07:07 AM
โMar-06-2016 03:43 AM
