Birds
Livies_Dad
For some reason some birds want to make their nest in the grill of
the RV. Saw one come out yesterday morning. Cleaned out lots of leaves and twigs. Last evening check and again full of leaves and twigs. Busy little things. I finally taped some plastic across the
grill to prevent access. Might one to keep a eye on yours if it sits near trees like mine does.
8 REPLIES 8
pegdiver
When we have our canoe on top of the car, we often have nests in the end of the canoe. Went for a walk in Florida and came back to a big wren nest. Every day we had to remove a nest, no matter where we traveled that year.
2012 Winnebago Adventurer 37F with 2012 Jeep Liberty toad.
Old - 1999 32' Adventurer (no slides) with Grand Vitara toad (105,000 miles!)
Pride 3 wheel mobility scooter
Only 3 states to go in the USA, Camped in most of Canada and 4 states in Mexico too!
rockhillmanor
That must be those tiny little birds! They ARE real busy ones. I had them make a nest in just a few hours of me parking! They decided to put their nest in the compartment where the electrical cord comes out which you can't close when hooked up.
I shooed them out of there and within minutes they then thought the back of the roof top air would be a good place. :C
crasster
Also those owls with the bobble heads work well.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Snowman9000
I have had good luck with a rubber snake.
Currently RV-less but not done yet.
netjam
Had gulls nesting between slide roof and slide topper. Finally had to pull in slides and move locations. Since then have put mothballs in that area at the suggestion of others and have not had the problem reoccur.
gbopp
Rubber snake?
stickdog
We had a bewick's wren setup housekeeping in our hitch. We were volunteering at the time at a wildlife refuge and told we couldn't leave till the little birds fledged. They did about a week before we were set to leave.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
romore
They are persistent. Last year the robins insisted on building on a tote box fastened under the nose of our fiver, I have to remove it before nesting season arrives or we will be parked until the young leave.
