Nov-04-2013 02:15 PM
Nov-06-2013 08:59 AM
Nov-06-2013 08:36 AM
John&Joey wrote:DanTheRVMan wrote:Bumpyroad wrote:harold1946 wrote:
All seams and protrusions should be checked at least once a year. I do it twice a year. The ac units have a gasket and require no caulking.
Fiberglass, whether a gelcoat or painted finish, should be waxed or coated with a UV protectant. It will oxidize just as any other finish.
Brite Tek requires only checking and resealing of seams and protrusions.
drive by any marina and note those chunks of fiberglass floating in the water. no waxing, no UV protectant, nothing except perhaps rubbing off algae every once in a while. other than caulking the seams and various things mounted on the roof, nothing else needs to be done.
bumpy
Not a good comparison
Boats are made of multi layered cloth and resin and are very strong and very expensive
Fiberglass roofs are chopped fiber and resin easily crack and are very cheap
I do not want to switch this to a tiffin roof cracking thread, but fiberglass is far from perfect
Yep, like apples are to oranges. Anyone who is using a boat hull to a RV roof for comparison is really showing how little they know on the topic and how much they rely on the internet for their information.
Not saying Brite Tek is the way to go, but it has many pluses that should not be dismissed. One of them is if you're buying a new rig why not use the saved money to get options that will make your life better during the time you own the rig. Who cares what the guy does 20 years from now that is buying the rig on the cheap.
Nov-06-2013 05:00 AM
bumpy
Nov-06-2013 04:08 AM
Nov-06-2013 03:19 AM
bumpy
Nov-06-2013 02:29 AM
Semi Retired Grandpa wrote:harold1946 wrote:Bumpyroad wrote:harold1946 wrote:
bumpy
I own one of those boats, and believe me they do oxodize and need protection from UV. Instead of just driving by, walk down and swipe your hand across the gunnel.
I guess it depends on whether one wants to keep it in top shape or let it deteriorate. Its pretty easy to spot the ones that are cared for and the neglected ones, even from a distance.
Go to the search bar and type in gel coat. You may be amazed at the number of posts regarding oxidation and fading of gelcoat.
Agree. Have left a sail boat in the water for extended periods - in saltwater on both east and west coasts - with very little maintenance required (teak trim being the only continual maintenance required other than annual bottom cleaning/paint). Also owned a trailerable fiberglass boat for 18 years w/o more than a general washing ever required to keep it looking like new. Also owned an Itasca MH with an aluminum roof for 18 years - used summer and winter - w/o so much as having to caulk a roof seam. More recently owned a Winnebago MH with fiberglass roof from 2005 until 2013 with extended trips thru the very hot SW and twice to Alaska w/o any roof maintenance - no caulking, no leaks, no problem. Looked like new when we sold it the first part of 2013. When purchasing a new MH eliminated from consideration all those w/o fiberglass roofs because of too many reported problems and long term maintenance requirements with other materials.
Nov-05-2013 09:20 PM
Nov-05-2013 09:14 PM
bumpy
Nov-05-2013 03:30 PM
Nov-05-2013 11:21 AM
bumpy
Nov-05-2013 09:13 AM
Nov-05-2013 07:50 AM
Nov-05-2013 07:45 AM
Nov-05-2013 07:27 AM
