Buying 08' Fleetwood Bounder 38B , Workhorse , any advice ?
oscar111
I'm close to buying a 2008 Fleetwood Bounder 38B on a workhorse gas chassis . We will be towing our '13 Jeep 2dr Wrangler . Any advice on this unit would be a big help . Will a gas coach of this size with the Workhorse have trouble towing my Jeep on steep grades . We are trading in a Hurricane 34B on a ford gas chassis . The Ford was quite capable of towing the Jeep but I can't get used to the high rpm's it requires to reach max. torque and H.P. .
Roger & Erica
2008 Fleetwood Bounder 38P
Workhorse W24
2013 Jeep Wrangler Sport
2 Sidekicks , Oscar and Elmo
6 REPLIES 6
timmac
It will tow it but 38ft is getting to the max weight that 8.1 can handle as far as I am concerned, your RPM's will still be high..
oscar111
Thanks for the reply's . The 38b came with the 24000 lbs. chassis . I've checked and it appears this chassis was not included in the brake recall .
Roger & Erica
Workhorse W24
Rocky2
Any suggestions for steep climbs...Ear Plugs.
bullydogs1
Just ensure that the brake recall was done on the workhorse chassis...you can call workhorse or go to the website with the VIN to check..hopefully the owner of the coach will have the paperwork if the work was done...if it wasn't I'd still buy the coach..but would not use until recall done.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
ArchHoagland
My 2004 with the 8.1 does mountains fine pulling my 4,000lb toad.
I am typically at about 45mph at the top of most mountains here in the west.
I climb mountains based on RPM where about 3800 RPM achieves my maximum torque.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
CT_WANDERER
I have a 36ft coachmen with the 454 gas engine on W22 Workhorse frame. I pull a 13' Wrangler 4door. I am at my Max with the setup. The Wrangler is much heavier than my last tow. I am happy with it, but it does use more gas. I have no problems doing hills, it might slow down a little. Gary
