Cable TV
RealRV
I have a Fleetwood w/Direct satellite & cable as well as Local TV antenna . I have been in parks which offer cable and my inside front TV picks up the picture and my outside as well as back TV will not get cable???? Go to another park and all TV's pick up the cable. Any thought on way this is happening?????
6 REPLIES 6
wa8yxm
There are now 4 different major types of cable and a few secondary
The major
NTSC: This is the old Analog Television, once all systems were like this
QAM (With sub settings) This is regular Digital Cable.. NOT ALL TELEVISIONS have a QAM decoder.. In fact the one brand that is still made (Actually once again made in the USA) does not decode QAM..
NTSC.. Some cable systems. like the one I'm on, Simply pass on the signal they get from Over the Air locals.. Do not change it to QAM as many others do.
ENCRYPTED: you need a "Set Top Box" for these, no matter your TV.
I have 3 TV's here too. one, when set to cable, does all 3 of the non-encrypted formats, QAM, ATSC and NTSC.. One only does NTSC and ATSC when on "Antenna" and QAM (or NTSC) on Cable (Will not display the digital channels on the local cable) the other two do all 3 when on cable ATSC, NTSC and Qam.
Very confusing.. thankfully I figured 'em out.
TechWriter
Some parks have digital cable and others have analog.
When all your TVs receive cable, my guess is that the park has analog.
When some of your TVs don't receive, the park has digital cable & the TVs that don't receive do not have QAM (ie, digital) tuners.
www.rvSeniorMoments.com
DISH TV for RVs
K_Charles
Maybe the front TV scans for both analog and digital and as said above, the rear TV doesn't. Like MaverickBBD said check and or fix that.
MaverickBBD
When you do a channel scan on back TV, what kind of cable does it search for? If it is not set on auto, do that and re scan.
Tom, Cheryl & Blossom(coonhound mix)
'05 Winnebago Journey 36G w/Cat. C-7 350 hp Freightliner XC
AFE air filter, aero turbine muffler, 4 FSD Konis, ultra track bell crank and Safe-T-Plus
FMCA 397030
WIT 129107
wildmanbaker
Do you have a distribution panel the all the inputs go to? Could be that the selector buttons were disturbed and not allowing the signal to go to the other sets. Otherwise you may have a bad connection somewhere is the cable distribution system.
Wildmanbaker
Mandalay_Parr
Cable signal may be a little low.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
