lbligh wrote:
GGROTZ,
Follow the link below to read exactly how CCC is calculated and what is included. Too important to listen to some that might be providing bad information.
Safe travels.
http://www.fulltime-rving.com/Cargo_Carrying_Capacity.html
In my opinion, a poorly written article. (More about that, at the bottom) However, the regulations (not laws) changed in 2008. The OP's rig is a 2005, so the old rules were used to calculate the CCC for his coach.
The old RVIA rules were
CCC = GVWR - UVW - propane - water - 154 * sleeping positions
UVW is the weight of the motorhme as built at the factory with full fuel, engine oil and coolants
That is the basis of the 2005 Pace Arrows 37a's ccc of 935 pounds.
Most RV's have more than 2 sleeping positions; lets say it has n sleeping positions. Then 154n - actual weight of occupants can be added to the 935. Carrying less than a full load of water can also increase the amount of other "stuff." But, don't forget that the contents of the grey and black water tanks are cargo and counts against the CCC.
About the article:
It starts by telling us the rules have changed, there is now an OCCC. It doesn't tell us that pertains to motorhomes and not trailers. Nor does it tell us there is a new CCC that pertains to trailers.
The article tells us:
The new OCCC label calculates the average 150 pound belted, seated passenger seat, plus the weight of fresh water cargo. This total cannot exceed the GVWR of the manufacturer.
Cargo weight includes the weight of the battery, propane, water, furniture, appliances, and all the stuff we have in our RVs.Battery, propane, furniture, and standard appliances are not part of the cargo. Under the new regulations, water is part of the cargo as are the occupants. And since the occupants are part of the cargo, the number of sleeping positions or belted seating positions is not used at all.
Then the article "shows" how to calculate CCC and use the old rules. At the start of this portion the article states:
The Cargo Carrying Capacity (CCC) of an RV is the GVWR less the empty weight, the weight of the full water tank, the weight of the full propane tanks and the sleeping capacity (My emphasis.)
And in step 5 the article states:
Subtract the weight of the seating capacity weight rating (SCWR) (150 pounds times the number of seating positions) (My emphasis.)
A poorly written article.
What is the new OCCC, which in now required to be posted on motorhomes
OCCC = GVWR - UVW - propane
The commentaries I have read state that propane is considered cargo, but the NHTSA regulations clearly state:
...the weight of full propane tanks must be included in the RV's UVWโฆWhat is the difference between OCCC and the old CCC? Fresh water now counts as cargo as do all occupants.
i mentioned there is a new CCC.
new CCC = GVWR - UVW - propane
Looks the same as OCCC. The difference is, OCCC applies to motorhomes, CCC applies to trailers, with the assumption, traveling down the road, there are no occupants in a trailer.
How did "belted seat positions" get into the regulation? As the regulations was first put forth, NHTSA wanted to subtract 150 times belted seat positions; RVIA wanted to keep the old 150 times sleeping positions. (RVIA didn't object to 150 as opposed to their previous 154.) That was resolved by counting occupants as cargo.
Sources: 49 CFR 571.110 as found on
www.law.cornell.eduand
Federal Register Volume 72, Number 232 That is a lot of technical reading. Note: Although UVW is used in the regulation, UVW is not in the list of definitions for the regulation. I used the commonly understood definition.
Tom
On edit: Insert 'not' in the last note to give the sentence the proper meaning.
2015 Meridian 36M
2006 CR-V toad
3 golden retrievers (Breeze, Jinks, Razz)
1 border collie (Boogie)
