Changing fluid in leveling jacks?
JerryofWV
I was reading the manual for my Power Gear jacks and noticed they recommend changing the fluid every 2 years.
I don't know anyone who has changed their fluid ever, much less every 24 months.
Does anyone change the fluid? Is it really necessary?
Jerry & Dee Dee Pauley
2005 Monaco Monarch SE, Workhorse, Falcon II tow bar, ReadyBrake, 2012 Jeep Liberty Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
16 REPLIES 16
Blaster_Man
If you change it, but sure the jacks are retracted, or you'll put in way too much fluid.
2014 American Eagle
tropical36
Believe it or not, there are still some people that are changing their engine oil every 3000 miles under normal conditions and evidently believing that it is contaminated or broken down in some way. Many will say that they've never had a problem by doing so. Well, they still wouldn't have had a problem with changing it every 6 - 7K miles either or even more.
It's no wonder that oil, fuel and other petroleum products have been so expensive, with the amount of waste that we create.
Now, where does it say to change engine oil every 3K miles, otherwise your engine is going to fail you. Only place I've seen this promoted extensively, is by the quick lubes and other stations that do oil changes and their favorite thing is for putting that little sticker on your windshield, which actually means nothing. Exp...there is a mileage reminder on the sticker for your next 3K oil change. So, evidently this means that if your vehicle sits for 5 yrs or so, it still isn't due for an oil change, right?
A little off topic here, I know, but the logic of it all still remains.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Valkyriebush
Never changed mine. Jacks Work perfectly. 12yrs. Never gave it any thought until now?
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
Effy
As my wife always tells me; "don't borrow trouble" .
2013 ACE 29.2
mtrumpet
dougrainer wrote:
1. Unless you put DIRTY trans fluid in the reservoir, there is no reason to replace the fluid.
2. HOW would you contaminate the fluid? It is a sealed system except for the reservoir fill area
3. Unlike Transmissions and other appliances that have mechanical gear parts that can wear out and get metal shavings in the fluid, JACK systems have NO parts to wear out and contaminate.
4. In almost 30 years of HYD jack systems and working on them, I have never changed out the fluid and have never been asked to change out the fluid. I also, have never seen or had a failure of a jack system and components that was because there was old/dirty/contaminated fluid.
5. Unlike Transmissions and such, there is NO HEAT or anything like that, to break down the Trans fluid.
6.If you want, you can change your fluid, but it is a waste of time and money. To properly change the fluid would require you completely drain the reservoir(easy on a PG system), not so easy on HWH/LCI type system. You then have to get rid of the existing fluid in the lines and in each jack cylinder. PG and HWH cylinders will have a minor amount of fluid. Power down and power up cylinders(LCI and such) will have to have the cylinders purged to remove all old fluid. Doug
Doug beat me to it, but I completely agree. He has covered it all in his excellent post.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
billsenick
Never on my 2003, since new.
Bill Senick
2011 Newmar Essex 4524
2003 Newmar Kountry Star 3740
cbeierl
Just fyi, for those with HWH jacks/slides, the FAQ on HWH's site says:
44. How often should I change the fluid in my system?
Rarely, only for a possible condensation problem or contamination problem.
Chris Beierl
2005 Winnebago Vectra 36RD
siggyd777
Oh NO, on electric jacks you need to change the Electrons !!!
Siggy
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2015 Jeep Cherokee,4x4 Active Drive II,V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283
dougrainer
PastorCharlie
Mine are electric and I change the Ions about every 6 years. ๐Ÿ˜„
John_Wayne
Change mine every 2 years and replace with Mercon V synthetic.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
J-Rooster
I've changed mine every 5 years!
Fun_33v
I change the dextron 111 every two years 5 quarts & it's good to go in my Kwikee 3000 leveling jacks.It's an easy job.
Trackrig
Yes, changed mine. When I bought IT, it was seven years old. After reading all sorts of recommendations of what to fill it with which scared me a little on what could be in it, so I changed it.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
