Aug-17-2013 09:39 AM
Aug-17-2013 05:01 PM
Pop-Pop C wrote:
Ok, I have the coach batteries under the slide out tray.
The caps are a hex and have a seal on the corner. Would have to
dig the seal out with a screwdriver. Take caps off with a socket.
Chasis batteries are the same.
First time I have expereinced this.
Aug-17-2013 04:12 PM
et2 wrote:Old-Biscuit wrote:
"...as the house batteries aren't easy to get at to check the water level or add any if needed."
And you're surprised 'they' didn't check them.
I do know the manufacture requires the dealer to keep the units maintenance up until sold. I was told that by Keystone at one time as I had a wheel bearing failure. So I would expect that it's maintenance should be kept up in order to validate the warranty.
Am I surprised they didn't check it or maintain it? Not one bit. And if I end up with a dead cell due to the water level being too low, I would certainly get the blame for not keeping it topped off.
Aug-17-2013 04:04 PM
Aug-17-2013 11:38 AM
Aug-17-2013 10:50 AM
zman-az wrote:
Were the batteries full charged before you filled them. Should never top them off when discharged as the fluid level will rise after they charge.
Aug-17-2013 10:48 AM
Aug-17-2013 10:07 AM
Aug-17-2013 09:58 AM
Aug-17-2013 09:48 AM
