city water fill help...
luvz2cook
hI,
I just bought a 2001 rvision trail lite class b+..
trying all the systems today...most everything works but...
when I hook up the city water to the unit and turn it on no water goes to the faucets...what am I missing??
also, filled the fresh water tank 1/3 full, tried the water pump...it sounds like its working but does not pump water to the faucets...it does pump water out of the drain even though it is closed (I think it is, nothing drains from it til I turn the pump on)
any suggestions...thank you,
christine
11 REPLIES 11
olygene
Why not join the rvision trail lite camping club forum for rvision owners. You will find info that are make and model specific as opposed to RVnet which, while very helpful and informative, is more general. On the rvision forum you will find input from other owners who have the same year and model as you and can respond with more precise information.
Harvey51
Our city fill check valve is broken so it doesn't close when our pump is running. That happened when I wondered what it was and took the cap off with the pump on - it blew. I put Teflon tape on the threads and capped it. it hasn't leaked. We have never hooked up to city water and probably never will. The pipes get flushed as we use the pump.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
jjson775
For what it's worth, we quit hooking up to city water early in our travels and haven't done it for years. It is more trouble than it's worth, we just rely on the pump. You do need to have the capability to hook up to city water, however, so you can flush the system. Good luck.
Jim
Old-Biscuit
luvz2cook wrote:
That's what I need to hear! Thank you! I was not familiar with the valve with the ring that you pull up on!! Got dark before I could figure it all out, but will fiddle with it today...trying to sanitize the tanks and check all systems on new toy....thanks again!!
City water fill valve must need replacing...will not take in any water....
the city water fill has an internal check valve (closes when using water pump).
They are just cheapo plastic junk.....plunger/spring/o-ring.....and can get jammed or o-ring falls out of position.
Check valve is probably jammed but also check that the screen/washer in the connection (garden hose washer with a screen) is clogged up with debris
luvz2cook
Gene_in_NE
luvz2cook - Christine welcome to the forum. Not sure what model you bought, but our model 211 has the pump and fresh water tank under the dinette seat. There are two valves next to that pump. One that looks like an old radiator drain valve
that drains the fresh tank on the ground. The other one has a ring that you pull up on to drain the water lines for winterizing (low point drain). This one often times has to be pushed back down. I suspect that this one is not pushed down and seated so both the pump and shore water is being poured on the ground under your rig. ๐Ÿ™‚
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
1492
Moderator
Moderator
Moved from Forum Technical Support
2oldman
Step 1: close that drain.
orlandimal
I had this problem once with my fiver and as it turned out the water pressure in the campground was low. I had to remove the water pressure regulator that I leave attached to my water hose. Once removed, water in trailer worked fine.
2008 Silverado 2500HD, Z71 off-road, Z85 towing
2005 Keystone Hornet 245RKS 5th Wheel
enblethen
Look for a fill valve. It could be in wrong position.
With pump on, it would just pump in circle back to the fresh water tank. In fill position it would fill tank.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
First off.......
Are you sure you are hooked up to 'city water' connection and NOT black tank flush system??
Do you have a 'water panel' with switches/valves? If so...you need to line up the switches/valves for city water
With water pump on Close that valve that water is coming out of....doesn't do any good pumping water out of the system onto the ground.
