Aug-21-2017 10:27 AM
Aug-23-2017 06:00 PM
Xaviar wrote:Bruce Brown wrote:
On the rubber roof, there is true EPDM rubber then there are the synethic types - big difference between them. I have a TT with a rubber roof and our MH has BriteTek, which some (wrongly) confuse with rubber.
EPDM isn't my favorite, we're on our 3rd MH with BriteTek, I'd buy another in a heartbeat.
Also keep in mind just because it says "fiberglass" doesn't mean it's quality material, some is about paper thin. Also keep in mind, like rubber, fiberglass will break down somewhat over time too. I also dabble in older tractors. I recently shipped a cab roof from one of my parts tractors to Louisiana. The roof I had was metal, it was replacing a fiberglass roof that had deteriorated past it's useful life.
Also "rubber" is a lot easier to replace. I did a new roof on our TT a few years ago, I did a buddies 5th Wheel last fall. I can't do a new full fiberglass roof in my garage, that's a factory job.
IMO I'd be more concerned in the roof condition than the material.
We've had a couple (all be it salesmen) tell us that the rubber roofs can get holes just as easily as being somewhere where a bird lands on it with some prey and is having lunch. Given the height and areas we'd go to in a motorhome -- that seems like a pretty high likelihood (though I suppose it could easily have been a perfect scare tactic as to 'why this is better').
Are you saying one of those two types of 'rubber' are better than the other?
I suppose the walls and roof (as well as mechanical parts) are my biggest concern over all as for what will last. Remodeling I can do all day long.
Aug-22-2017 02:17 PM
BigRabbitMan wrote:
Here is a link to FMC motor homes. They are all 29 ft long with a rear engine. Originally they were all Chrysler 440's, but a number have been converted to diesel. If you are going to tow, a diesel would be preferred but a number tow with the original 440.
FMC photo albums by BigRabbitMan
Bring up BigRabbitMan's photo albums (that's me) and look for the various Rally photo albums to see a number of them. The roof and wall down to the beltline is all one piece of 1/4 inch fiberglass. Nothing is laminated nor are there any wall or front cap seams. I like mine, but it may be too small for you. I have put 75,000+ miles on mine over 15 years. I did upgrade it to a diesel 25,000 miles ago. PM me if you want more info as to floor plans etc.
Aug-22-2017 10:23 AM
Xaviar wrote:fulltimin wrote:
You tube has a bunch of videos on converting a bus to a motor home. Many, but not nearly all, are school bus conversions.
Buses can be had from 20' or so up to 40'. It's not too difficult to find a 35 footer. Some are cab over, some conventional, depends on what you prefer.
One thing about the bus, you will be able to install heavier components, without the worry of going over your gross weight.
Do not fear plumbing, it is one of the easier, simpler jobs. Not much required in the way of tools, or special skills.
Link to you tube bus conversions
What makes the difference on the gross weight where it can handle it so much better? Just a better chasis/engine?
What's the typical life expectancy of the engine in the busses vs RVs? It occurs to me I keep comparing them to cars -- and yet I've seen a couple listed as "low mileage" at 100k miles.
Aug-22-2017 09:48 AM
Aug-22-2017 09:04 AM
Aug-22-2017 08:51 AM
Aug-22-2017 08:23 AM
Gjac wrote:
Having spent time fixing delaminated side walls I would take Bruce's advice look for one with a hung wall, they can leak but not delaminate. $25k or less would probably be about 15 years or older so maintenance is important. If gas I would choose a straight axle front end over an IFS P-30 chassis a lot less maintenance. After 2006 both Chevy and Ford had good chassis and eng HP. Before that I would look for the WH chassis with the Alison transmission. Also look at things like FW capacity, storage, and CCC. These things are more important to me that the type of roof it has especially storage and the CCC if you plan to fulltime for a couple of years. If you plan to camp in NP's, NFS, SP's CG's without full hook ups them FW, black and grey tank capacities are important also. What sort of mods are you anticipating to make?
Aug-22-2017 08:20 AM
Bill.Satellite wrote:gbopp wrote:Bill.Satellite wrote:
Get an older Prevost and you will be good to go. Steel, stainless, aluminum and fiberglass caps.
Excellent idea.. But they are not cheap.
No, but after you are done with it in 2 years you will be able to get most of that money back when you sell it especially if you do a nice job on the updates and upgrades.
Aug-22-2017 07:00 AM
Xaviar wrote:That's fair 🙂 Just more than I might be willing to take on.Mile High wrote:
I don't understand your statement that MH are wasted space for 2 people - we found quite the opposite- the higher end you went the more tailored they are for 2 people. The entry levels are typically the bunk houses, sleep 10, etc.
I would never predicate a 2 year journey on having to gut and rebuild a motorhome unless you really just have nothing else to do. A) It would take me 10 years to finish that kind of project, B) when I was done I would have a MH that only I liked and I could never sell it because no one else liked it 🙂
Just because we intend to be on the road consistently for two years, doesn't mean I'd stop using it. We just have some other ideas/thoughts/plans after that -- where it would likely be more casual. Or who knows! Maybe we'll love it and do it forever.
Aug-22-2017 05:28 AM
Excellent idea..
Aug-22-2017 04:20 AM
Aug-21-2017 08:24 PM
Aug-21-2017 07:39 PM
Aug-21-2017 06:53 PM
