Class A metal roof sealant
was_butnotnow
I have a Monaco Class A with a metal roof and the sealant is starting to check. Wonder if this is what I should use to reseal it.
See pics. Not the whole roof just over the seams.
Now in a 05 Monaco Cayman DP 36 PDQ
Traveled many years in NuWa Hitchhiker 5th wheels.
Travel Journals and Adventures of people living this lifestyle
Hitchitch.com
Personal blog with our own travels. www.fulltime.hitchitch.com
4 REPLIES 4
DFord
Clean and dry the joint real good first. Then cover it with a roll of Eternabond and you'll never have to seal it again. The stuff is great!
https://www.bestmaterials.com/Eternabond.aspx
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
tomgagne
I have a metal roof on my Monaco and I’ve done what gbopp has recommended. Eternabond on the seam. Just clean the dirt and you can apply the tape right over the existing chalking. They have a role which is 6 inches wide. I’ve had the coach 12 years and the eternabond has been on it for 7. Follow the directions and you can be done in a few hours
gbopp
I've never owned a metal roof but, I would clean the seams and cover them with Eternabond.
Lwiddis
For a metal roof, yes. I wouldn’t wait for cracking or whatever you wrote. At least yearly maintenance is essential. You’ve been lucky.
