Coleman AC. Should we upgrade to heat pump
susblum
Our 2017 Jayco has a Coleman AC. We miss the Dometic heat pump that was in our Forest River. Thinking of pulling out the AC. Any feedback on upgrading to a heatoump
Is one brand better than another? What about a heat strip. We are sucking down too much propane.
17 REPLIES 17
stickdog
We use our heat pump along with ceramic heaters. They both have their place. That said I would not pull a working AC just to replace it with a AC/HP.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
msturtz
A heat pump is economical to operate and distributes even dry heat. I had them on a prior rig and really liked it. It does not use nearly as much energy as a radiant heater or strip heat.
FMCA member
WILDEBILL308
You could just buy a couple ceramic heaters it would be a lot cheaper.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
