I've noticed a crack at the joint between the body of the RV and the cabover; the cabover, at the sides, seems to lap over the body. One side's tight, but the right side has a crack that gets wider from top to bottom, shown here:
At its widest, at the bottom, it's about 3/8" wide.
Is this a sign of a structural problem? I don't see evidence of sag, and the joint where the cabover sits atop the cab proper (the part built by Mercedes) seems to be tight and stable. I'm not seeing signs of cracks in the adjacent body-to-cab connections below that crack (haven't yet crawled up on the roof to inspect). Are there tests/checks I should be applying/making to determine if I've got any structural issues?
If it's not structural, I assume I should caulk it. I'm familiar with architectural caulking practice (houses and the like): thoroughly clean out the crack, push backer rod into the crack as soon as it's large enough that I can do so, and apply and tool smooth a suitable caulk. Several questions there:
1. Is there any difference in the steps in caulking with an RV?
2. In architectural practice, you never caulk the lower side of a crack like this; any water that gets in needs to escape, and water always wants to flow downward. Would that be true here as well?
3. Any recommendations for a caulk? It would clearly need to be highly flexible, with good adhesive properties. Sikaflex makes a lot of good caulks, and I imagine one of their products would be a good choice, but I want the best/most suitable product here.
If there's something else I've forgotten to ask, I'll be grateful for that, too.
