Cummins El Paso
smlranger
I may have to get someone to look at our ISL and our travels will take us thru El Paso after a week stay in Kerrville, TX. Anyone have any feedback on Cummins Rocky Mountain in El Paso? My coach is well out of warranty so would be fine with a good independent shop if they know their way around Cummins engines. I am having intermittent low fuel pressure events which cause loss of power. I have changed my fuel filters twice in the last 900 miles and problem goes away for a day or two then returns. I had this problem last year but my local Cummins shop could not duplicate it and said they thought I should just treat my fuel for algae, which I have done and continue to do.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
27 REPLIES 27
smlranger
RandandDoug wrote:
I had the same "sounding" issue a couple years ago, and it was a sensor on the fuel rail. Hope yours is just as easy.
Was the issue intermittent/unpredictable?
RandandDoug
smlranger
artillery6 wrote:
We have used Rocky Mountain in El Paso and found them to be very professional and know what they are doing. I would recommend them.
Thanks. That is good to know. While I am hoping the diesel shop here in Kerrville can diagnose and fix the problem, it is good to know we still have a good option on our route west.
artillery6
smlranger
I understand the injector pump is very expensive. I would also be more inclined (unless the mechanic has proof/evidence of something else failing) to have them replace the fuel rail pressure sensor and switch.
moisheh
Ray: a 559 code can be many different fuel problems . Could be the pump, could be the sensor, pressure switch, filter related and more. I saw on the Cummins computer a page or 2 of the possibilities. Cummins has a specific order to do the tests. Nothing is ever as simple as throw on a new pump. When I had them replace the switch and sensor I already had a $1500 bill. I simply told them to replace the 2 items. It worked.
Moisheh
Tom_Barb
RayChez wrote:
Yea! code 559 is low fuel pump pressure. Might have to change out the fuel pump.
I'd certainly check the pressures with a direct reading gauge prior to committing to a new pump.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
2gypsies1
Fiesta wrote:
To answer the OP. We lived in El Paso for 22 years. The service there was terrible. Too many across the border mechanics....
Make sure the person working on your vehicle is truly certified by actually looking at his/her credituals.
Are you talking about the Cummins facility? Their mechanics have specialized training.
Or do you mean the general repair shops?
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
RayChez
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Fiesta
smlranger
moisheh wrote:
Access is dependent on your unit side V rear rad. On mine it is very easy to open the hatch. It is not in the floor under the bed or in the closet. I opened it up but the mechanic was able to climb into the engine compartment and reach. You need a skinny mechanic. There is one other possibility for your problem. When they removed the filters were they full? Are the thick o rings installed? On mine there was one filter mounting flange that was not machined straight. Don't know how it worked for 7 years. BTW there is a new improved filter . I am sick today so cannot get it but hopefully will find the # tomorrow. If the only code is that 559 Cummins has a whole list of things to check or replace. But I would suggest to just do the things I did. Anything else is going to be mega bucks. Do you have those plastic fuel lines? Could one of them have rubbed on something and made a pin hole? Please keep us posted. ON EDIT: What brand of filter are you using?
I have side radiator but access on the fuel rail side of the engine looks tight. To access top of engine, I have to remove the two wardrobe doors (have to remove bottom track to remove access panel in floor) and raise the bed.
Whenever I have removed my filters, they were full of fuel. My primary has 1" threaded stud and that filter uses the center rubber o ring. My secondary filter head has 7/8" stud and it is pretty short and there is no center o ring. If you try to put the o ring on that stud, there is not enough thread left to get the filter on.
The large diameter line from the tank to the inlet of the primary filter head appears to be a hard plastic. The line out of the primary and both lines on the secondary are some sort of nylon mesh wrapped lines.
I am under the impression it cannot be a bad lift pump since on our engine the lift pump only runs briefly, then goes into a bypass mode and a mechanical pump takes over.
I do remember my local Cummins shop telling me the diagnostic time and effort related to the 559 code was lengthy and expensive. I certainly don't want to tell the mechanic what to do but I do plan share your experience with him. I will be at an independent shop so not sure if they have the full access to all things related to Cummins.
moisheh
smlranger
moisheh wrote:
Fuel problems
I had a similar problem and a Cummins specialist could not fix the problem. Did some googling and 2 or 3 other ISL owners had the same problem. It was the fuel rail pressure switch and sensor. Even though they were faulty it did not show up on a test. Parts are about $250.00 . Were you getting a 559 code? You might have to join IRV2 to read the above link.
Moisheh
I get code 157 on my Silverleaf which is the same as Cummins 559 code. I changed my filters yesterday and only got from San Antonio to Kerrville, TX before it reared its head. 30 mph up the grades is no fun.
I have an appointment with LeMeilleur's RV/Truck repair in Kerrville early next week. They say they think they know the likely cause but will need to do the diagnostics. I will share your info with them.
Do you know if you can get to the rail pressure switch and sensor without getting to the top of the engine? Just curious if we need to get stuff in bedroom out of the way so they can work from top or bottom.
Tom_Barb
I'd replace the whole filter to a Raycor
230R10 would be the one I'd use
